Footwell lighting strange behavior
Old Feb 20, 2013 | 07:29 AM
TGED's Avatar
TGED is infamous around these parts
I find it quite odd that all 4 foot well lights remain on after all the doors are closed on our Cayenne S. Is this normal? We have comfort light pkg but no extended LED pkg.
Old Feb 20, 2013 | 07:44 AM
LaicepsYdobon's Avatar
LaicepsYdobon is infamous around these parts
Completely normal and visually appealing
Old Feb 20, 2013 | 08:44 AM
dimok's Avatar
dimok is infamous around these parts
Normal
Old Feb 20, 2013 | 09:17 AM
TGED's Avatar
If the foot well lights do stay on, at least they should be at a reduced intensity, similar to our previous MB S class. Perhaps I should look into changing the bulbs to LED.
Old Feb 20, 2013 | 09:20 AM
gasmanavo's Avatar
gasmanavo is infamous around these parts
You can turn the lights off by using one of the buttons near the sunroof controls. You can also dim the light using the same control.
Old Feb 20, 2013 | 09:32 AM
TGED's Avatar
I do not want to switch them off, because then they will not come on when a door is opened. I will try to dim them and hope the reduced brightness stays and I don't need to adjust them every time. The footwell lights do stay on day and night regardless if the headlights are on. And you said this is normal!
Old Feb 20, 2013 | 04:08 PM
Harlequin NY's Avatar
Harlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of light
I have them very dim for effect and that level stays automatically every time I start the car. It is really a great feature but I don't know if it there only when you get the extended led package which is what I have.
Rob
Old Feb 20, 2013 | 04:27 PM
TGED's Avatar
I will try to dim mine tonight as I don't have extended LED. Are your foot well LEDs cool white like the overhead horseshoe light?
Old Feb 20, 2013 | 05:04 PM
All the lights are led which are bright and clear. They look great at night inside the car and the outside is stunning also.
Old Feb 20, 2013 | 05:46 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
I'd like to have the footwell lights, but I can't figure out how to have them without the ring (without removing the bulbs). Even at its dimmest its way too bright for night driving.
Old Feb 20, 2013 | 06:06 PM
I understand. I had to play with it several times to get the horseshoe dim enough to not be annoying and the foot well lights then are forced to be fairly dim also. I am used to the level now and it seems to do the trick!
Old Feb 20, 2013 | 06:19 PM
TGED's Avatar
I just tried, so even on non LED version the foot well lights are dimmable, but only together with the LED horse shoe lights, I wish I could adjust the foot well lights independently. But I still prefer it this way rather than on our 2011 Panamera which the foot well lights turn off completely when all the doors are closed. Now I am looking to change the foot well lights into LED, I know Suncoast Porsche sells the retro fit Extended LED pkg, but I don't need to change all the other lights to LED as those lights do not stay on for long, door edge locator lights, trunk lights, sun visor lights, glove box light, etc. I hope I can just purchase the 4 foot well LED bulbs.
Old Feb 27, 2013 | 12:46 AM
ACar's Avatar
ACar is infamous around these parts
I have the comfort light pkg without extended LED. I changed the footwel, trunk, rear lift, glove box, and door lights to LED. Did not attempt the visor and side mirror lights.
A very simple DIY. Just buy a bunch of type 194 from eBay (cost less than $1 each), and a 39-41 mm for the trunk. I also got a couple of error free 194 for the license plate.
Total cost for all the bulbs cost less than $30 shipped to the door.
Old Feb 27, 2013 | 04:14 AM
TGED's Avatar
Are these LEDs dimmable? For footwell lights they need to be dimmable.
Old Feb 27, 2013 | 01:04 PM
LGPM's Avatar
LGPM is infamous around these parts
What are the exact sizes or the led light you got? Footwel, trunk, rear lift, glove box and door lights?
