Can tires be repaired?
Old Apr 23, 2013 | 02:04 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
Originally Posted by steph280
careful using that sealer kit. It leaves a whole mess inside the tire, and you will hear a mouthful next time when you get your tire replaced. This is discussed in the 911 forums.
Plus will probably need to replace the TPMS indicator.
Old May 6, 2013 | 02:10 PM
nhirsch's Avatar
nhirsch is infamous around these partsnhirsch is infamous around these parts
Had discussion with dealer today on this subject. They recommend tire plug as opposed to resealing kit as long as the hole is inside of the first groove after the first outside thread on each side. inside groove to grove area is OK. The resealing kit is only temporary fix and needs to be cleaned up and may cause sensor issues.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
PAULUNM
14
May 27, 2016 06:54 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
immaculate
Aug 31, 2015 05:32 PM
