Bose or No-Bose?
Old Sep 18, 2013 | 08:40 AM
speed21's Avatar
Originally Posted by gnat
Bummer. Maybe my misspent youth is starting to catch up with me...
Lol...couldn't be more misspent than mine....so no that's not what's causing it..hehe...
I think if op has the option of one with Bose for the extra $ it would prove worthwhile in the long run. On the other hand if he doesn't then I'm sure he will live without it. Fwiw I also found when listening to just the radio the base system was really weak against the Bose. Maybe it's just the size of interior space that makes it that you need a sub and better speakers..
Old Sep 18, 2013 | 09:23 PM
TGED's Avatar
TGED is infamous around these parts
I have Bose in my Panamera and PCM(non-Bose) in my Cayenne, and both radios are bad, FM is barely acceptable and AM is just horrible, the tinny and weak AM sound makes it feel like I am listening to a tiny pocket radio, by turning up the volume does not help.
Old Sep 18, 2013 | 09:26 PM
TGED's Avatar
Do you have any idea if "loudness" was turned on or not? I was highly disappointed in the base+nav system as I drove it off the lot and intended to go straight to my audio guy to start discussing options. A few miles later I found and disabled that "feature" and it made a world of difference and I'm happy enough to live with it as is.
That "loudness" option just ruins it and I have no idea why they built it the way the did. It made it sound like the speakers were being overdriven while being under water. Just horrible.
Well said.
Old Sep 18, 2013 | 09:28 PM
TGED's Avatar
You guys keep talking about base, Bose and Burmester. There are actually FOUR different systems. The PCM/Navi is much better than the base system and it is quite comparable to the Bose.
Old Sep 19, 2013 | 06:48 AM
rc2080's Avatar
rc2080 is infamous around these parts
I have the fade shifted a couple of points to the rear, reduced the treble slightly, bumped the bass a point or two, and most importantly turned off the Loudness option (this made the biggest difference going from pure crap to a pretty reasonable system).
After reading your post, I put the fade on mine a few points back.. makes a world of difference!
Old Sep 19, 2013 | 07:43 AM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Happy to help.
As was touched on in other posts, timing adjustments make a massive difference in perceived quality of sound as it focuses the sound at a given point (usually the driver) so sound from all speakers reaches the point at the same time. Most vehicles are setup so that the majority of the audio power is focused on the speakers in the front half of the car. On systems that don't have timing control you can cheat by using the balance and fader to simulate the functionality to some degree. It will never be as good as true timing adjustments, but it can bring a garbage system up to acceptable levels.
Old Sep 19, 2013 | 08:18 PM
Needsdecaf's Avatar
Needsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud ofNeedsdecaf has much to be proud of
Happy to help.
So I have no loudness switch.
I have a "linear" setting which is "recommended for enthusiast listening" or some such nonsense description and a surround setting.
Is this a 2014 only thing?
Either way, I am having a hard time getting good sound out of this radio. I used to get into my BMW out of the Acura and think "man, the BMW sounds so much better". Now I drive the Acura every day and get into the Porsche and think "man, the Porsche sounds like crap".
HELP!
Old Sep 19, 2013 | 08:34 PM
TGED's Avatar
The Loudness button is only for the PCM/Navi audio system. Bose system has the linear and surround settings.
Old Sep 19, 2013 | 09:14 PM
gnat's Avatar
I have the Base+Nav stereo so don't have experience trying to tune the Bose system and I have no idea what functions it has and how they impact the sound. Hopefully someone with the Bose can chime in to help you out.
Have you gone back to your dealer and played with stock models to see how they sound? It could be that maybe there is something wrong with your system (I don't think the value is there for the higher systems, but they shouldn't make you pine for your Acura...). If you do that, make sure that you use the same source (e.g. CD, iPod, etc..) so that you are comparing apples to apples.
Old Sep 20, 2013 | 06:59 AM
X5B4's Avatar
X5B4 is infamous around these parts
HELP!
the linear setting is also on our 13 Bose C6. Profound changes it does not produce...
Old Sep 20, 2013 | 07:27 AM
TGED's Avatar
The Linear and Surround settings are nothing new, we have them on our 2011 Panamera 4 Bose system. We switch both on all the times.
Old Sep 20, 2013 | 09:34 AM
Harlequin NY's Avatar
Harlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of light
The surround setting on the BOSE changes things alot but it is difficult to go back and forth to compare becuase the program gets much louder when you turn it on. So I am often turning it on and off AND adjusting the volume quickly to try and compare the two. I go back and forth not sure which I like better. They both sound good to me.
I believe that 2 speakers come on during SURROUND all the way in the rear that are not on when it is off. The only improvement I would enjoy is a deeper sounding sub woofer.
I looked at a whole series of old postings where several people removed the BOSE amp and sub and substituted their own amp and cabinet. I think they all were on older Cayenne models but the results were good. Someday- maybe.
https://www.6speedonline.com/forums/...b-upgrade.html
jabed92694
Apr 3, 2016 11:31 AM
calexand
Nov 5, 2015 01:05 PM
MeddlingKid
Oct 20, 2015 07:43 AM
Gusto88
Sep 22, 2015 08:46 AM
