CTT 21" Replacement Tires
Old Feb 25, 2014 | 09:11 AM
JimGT3's Avatar
JimGT3 is a jewel in the roughJimGT3 is a jewel in the roughJimGT3 is a jewel in the roughJimGT3 is a jewel in the rough
Originally Posted by Fkim011
I had the Advans on my Cayenne GTS and they are the stickiest tire by far but as they started to wear out, the road noise started to increase too. Also, I didn't get much life out of my Advans (18K) vs the Michelin Latitudes I replaced it with. The Latitudes run much quieter, almost as grippy and has much better wet handling in my opinion. I got 32k out of my Latitudes with the same driving patterns.
Tried the Yokos and with about 50% tread remaining the road noise became a droning sound that was still tolerable until towards 2/3rds I had to change them out because of the noise.
Old Oct 17, 2014 | 08:19 PM
super50's Avatar
super50 has a spectacular aura aboutsuper50 has a spectacular aura about
All those here with Michelins still happy with them?
The time to buy new tires is close....
Old Oct 19, 2014 | 12:25 AM
Harlequin NY's Avatar
Harlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of light
Like my Michelins a lot. But I have ruined 2 of them hitting potholes.
Old Oct 22, 2014 | 01:54 AM
philipclaridge911's Avatar
philipclaridge911 is infamous around these parts
Covered 13k miles so far with my Michelins. Mostly Motorway use, started with 8mm, now have 6.1 on the front and 5.1 on the back. So pleased with the wear rate.
I've started to get a slight droning noise at the front above 70mph. I don't think it's the tyres because I've just swopped the fronts with the back (cos the backs always wear slightly quicker) and the noise is still there, so it must be the start of a future wheel bearing failure. Time will tell.
Old Oct 30, 2014 | 04:36 PM
bob242's Avatar
bob242 is infamous around these parts
I saw a 2015 CTT yesterday brand new from factory.
Yoko it has !
Old Jan 6, 2015 | 09:17 AM
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
Michelin Latitude Sport wears well and doesn't get too noisy with age. have 21k on my set and the fronts (out edge - alignment) are due so I intend to replace all them. After some investigation on TireRack it seems the Conti CrossContact UHP appears to have an edge on the Yoko Advan Sport and both cost a fair amount less than the Mich. Having been through this before with several other P-cars I know there can be HUGE differences in wear and noise as the tire ages. I don't want the noise as the tire ages and would prefer to have great dry traction.
One thing the dealer told me was that they could NOT rotate the wheels (I have stock 21" Turbo II's) so could not balance the wear out. Anyone else hear that??
Old Jan 6, 2015 | 09:18 AM
Vyper340's Avatar
BTW - anything over 15k miles is considered for CTT tires based on owning several of them since they were introduced. Getting 20k or more is "exceptional" and I've been pleased with the wear of the Mich's with only marginal road noise increase as they get to that point.
Old Jan 7, 2015 | 09:09 AM
Well I've rotated mine myself on my CD (fronts to back, and lefts to right and vice versa) without any issues, so I don't know what your OPC is on about. Maybe they want to sell you some new tyres.
The reason I did them lefts to right and rights to left was to try and cure a mild droning noise at around 70mph, which appeared before the swap. It didn't cure it, but the noise is ebbing away so I presume it's a wear-phase characteristic with the Michies.
It wouldn't, however, stop me from buying another four in future.
15k on this set and only half worn (mainly motorway and a bit of town).
Old Jan 7, 2015 | 08:16 PM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
Rotating left to right and right to left..... is a no no.
Pretty sure my owners manual say front to back, back to front only.
Old Jan 7, 2015 | 09:30 PM
HOiYA's Avatar
HOiYA is infamous around these parts
I thought you could do a rearward cross or x-pattern:
Old Jan 7, 2015 | 09:58 PM
BlazinPond's Avatar
This is what i have been going by.
Cayenne user manual - sentence in bold on the bottom right part of the page...
"Tires must always remain on the same side."
Name:	Screen Shot 2015-01-07 at 10.55.33 PM.png
Old Jan 8, 2015 | 04:36 AM
I see it, but I don't get it.
Cayenne tyres aren't directional, so unless the fact that there maybe some sort of braiding memory that builds up in the structure of the tyre, and reversing this could affect handling is a issue - I don't understand.
Old Jan 9, 2015 | 06:21 AM
Vyper340's Avatar
To amend an earlier statement: I had my dealer contact tech support to clarify the rotation (front to back) which they had originally told me was not possible. They have know corrected that position and indicate it is possible on CTT but not on CTTS. Would have been good info to act on several months ago...
Old Jan 9, 2015 | 11:23 AM
HOiYA's Avatar
Did they tell you why it's not possible on the CTTS?
Old Jan 9, 2015 | 12:05 PM
Vyper340's Avatar
Staggered or spaced wheels I think.
