2013 V6 Engine Oil
Old Feb 27, 2014 | 11:29 PM
ychic's Avatar
ychic is infamous around these parts
2013 V6 Engine Oil
I'm due for an oil change and about to change it at home. What oil do you guys recommend? Based on my research, for v6 model, Mobil 1 5w30 is recommended. Is it okay to use Mobile 1 0w40 instead? Also how many litters or quarts do I need? I tried searching v6 engine oil amount and was not successful finding a solid answer.
Old Feb 27, 2014 | 11:50 PM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
7 quarts. Buy it from Walmart
Old Feb 28, 2014 | 02:21 PM
ychic's Avatar
5w30 or 0w40? My local walmart has bunch of 0w40 in stock but not the 5w30.
Old Feb 28, 2014 | 04:11 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
either or will work fine.
Old May 25, 2014 | 11:00 AM
kitae80325's Avatar
kitae80325 is infamous around these parts
I asked the same question but we are supposed to use vw504 or porsche c30 for v6 and diesel. For mobil1 it is 5w30esp. M1 0w40 is vw502/505 porsche a40 which is for all the other except ours and diesels.
Old May 26, 2014 | 08:48 AM
grohgreg's Avatar
grohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of light
x2. Stick with a C30 spec oil
//greg//
Old May 26, 2014 | 02:33 PM
kitae80325's Avatar
//greg//
Its been about 500miles since dealer flushed with 0w40 a40 on my car...u think it's imperative i flush it again now or i be okay for couple thousand miles? Say another 3000....
Old May 26, 2014 | 05:38 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
As we already said in your other thread, you should be fine.
Old May 26, 2014 | 06:02 PM
kitae80325's Avatar
gotcha. Thanks!
Old Jun 20, 2014 | 08:15 PM
sighting's Avatar
sighting is infamous around these parts
there was TSB with oil recommendations.. from porsche.. let me find it
Found it..
File Type: pdf
Old Jun 21, 2014 | 09:46 AM
kitae80325's Avatar
Found it..
Thats a porsche a40...we talkin c30 for v6
Old Jun 21, 2014 | 03:10 PM
sighting's Avatar
Here you go..
File Type: pdf
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 28, 2015 11:10 AM
ECS Tuning - VW
Aug 27, 2015 08:50 AM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
