Wheel bolt torque 118ft/lb??
Old Jul 9, 2014 | 06:59 PM
kitae80325's Avatar
kitae80325 is infamous around these parts
2014 cayenne 20inch wheels....is 118 correct?? Thanks in advance
Old Jul 9, 2014 | 08:40 PM
stevefrommn's Avatar
stevefrommn has a spectacular aura aboutstevefrommn has a spectacular aura aboutstevefrommn has a spectacular aura about
Should say in owners manual. That is what my 997 is.
Old Jul 9, 2014 | 09:17 PM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
Via google, i found a 2011 958 Porsche Cayenne owners manual (p. 275) which states:
Tightening torque for wheel bolts: 118 ftlb. (160 Nm).
Old Jul 10, 2014 | 11:44 AM
wallmon's Avatar
wallmon is infamous around these parts
Guess they want them to stay on!
Old Jul 10, 2014 | 03:45 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
seems like its a bit excessive, I noticed that also when I read the manual. I torque mine with a snap-on torque wrench at 100lb/fts. all my other cars usually in the 80-85 range. Ive done 140mph in my cs and my wheels didn't come off at 100ft lbs. lol
Old Jul 12, 2014 | 11:07 AM
grohgreg's Avatar
grohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of light
Well, older alloy rims were softer. You had to stop in the 80-85 ft-lb range to avoid cracking the rims. Newer alloys likely have higher tensile strength. As far as the newer spec, I think they're erring on the side of safety (aka lawyer-speak). The 2011 Touareg I had before the Cayenne was even worse, they spec 133 ft-lbs. I too only have a torque wrench that goes up to 100. Aggravating.
//greg//
Old Jul 12, 2014 | 11:15 AM
Enilder's Avatar
Enilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond repute
Yeah, otherwise you lose a nut.
Old Mar 2, 2015 | 06:57 AM
carlosC4S's Avatar
carlosC4S is infamous around these parts
I wanted to check mine (2010 CTT UK car) to see if a knocking noise is a wheel that has worked loose after recent refurb (although it sounds like a ball joint / bush tbh) but cant find the wrench anywhere in the car, I dont have a space saver spare and it appears no jack or wrench, is that right?
Old Sep 27, 2020 | 04:04 PM
Krinsky1965's Avatar
Krinsky1965 is infamous around these parts
Refer to your manual and not any of us (knuckleheads)
Old Sep 27, 2020 | 04:07 PM
BlazinPond's Avatar
And you felt the need... on your second post to drag up a 2014 question.
You sir...have so much potential here.
swisstony
Sep 12, 2018 05:19 AM
Waitin4Dv
Cayenne 955/957
Jun 5, 2015 11:04 AM
Aperture776
Cayenne 958
Nov 24, 2010 03:45 PM
cay_s
Wheels/Tires
Mar 7, 2009 04:43 PM
