High pitched Screeching sound when braking.
Old Jul 12, 2014 | 07:43 AM
Rkeeper's Avatar
Rkeeper is infamous around these parts
Hi guys, i noticed that my v6 958 started having very high pitched screeching sounds when i brake at certain speeds. The screechings are pretty obvious when for the first 5-8km, but it is not always the case. I tried braking at various speeds but it seems like the sounds are produced during intermittent braking as opposed to sharp braking at high speeds.
The milelage is at approx. 14000km.
Appreciate your advise. Thanks in advance!
Old Jul 12, 2014 | 10:26 AM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
if you take it to the dealer, they are going to say its normal. even in the manual, it states that brake noise is normal as they are high performance brakes.
Old Jul 12, 2014 | 12:27 PM
xray doc's Avatar
xray doc is infamous around these parts
Been told from a Cadillac dealer that this noise is normal in cars with majority city driving. A couple hard stops will help reduce this high squeak.
Old Jul 12, 2014 | 06:30 PM
RedBent's Avatar
RedBent is infamous around these parts
It's probably nothing; especially if you're only really noticing it at lower speeds or when the pads are cold. Like people above said, they're "performance" pads and they make a little more noise than you may be accustomed to.
Old Jul 12, 2014 | 07:33 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
It could also be a rock or something caught between the pad and the rotor. Sometimes that stuff will come out on it's own and others it won't. Also pop off your wheels and give your rotors a good look to see if there are any scratches as that would indicate something caught.
If it will do it at slow speeds, have someone be outside and see if you can narrow down the wheel(s) that it's coming from.
Old Jul 12, 2014 | 09:05 PM
Rkeeper's Avatar
Thumbs up
Thanks guys! Appreciate it.
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Jun 10, 2017 07:45 PM
