lug size?
Old Feb 23, 2015 | 02:26 PM
mmdht2's Avatar
mmdht2 is infamous around these partsmmdht2 is infamous around these parts
lug size?
what size are the factory lugs? would these fit?
http://www.ebay.com/itm/20-Premium-B...d5c7b8&vxp=mtr
when you get new wheels, the lug size should stay the same, right? or does the thickness of the metal (wheel) varies among wheels requiring different size lugs?
Old Feb 23, 2015 | 03:49 PM
snzuloz's Avatar
snzuloz is infamous around these parts
Originally Posted by mmdht2
what size are the factory lugs? would these fit? http://www.ebay.com/itm/20-Premium-B...d5c7b8&vxp=mtr when you get new wheels, the lug size should stay the same, right? or does the thickness of the metal (wheel) varies among wheels requiring different size lugs?
Typically the standard hardware fits most aftermarket wheels in terms of length, sometimes they require less width or tooling to fit into the recesses for the lug bolts. Only time length is factored into situation is when spacers are being utilized.
As far as the ones you linked, you would need to verify against what you currently have in place.
Old Feb 24, 2015 | 09:02 AM
johnstoy's Avatar
johnstoy is infamous around these parts
The lugs shown in those pictures won't fit any factory Porsche wheels regardless of the length or thread pitch: Porsche uses curved / mushroom shaped shoulders not cone shaped as shown in the pictures.
Old Feb 24, 2015 | 09:51 AM
mmdht2's Avatar
thanks!! u just saved me from a lot of frustrations. Porsche uses "ball seat" instead of "cone seat". I will take the current one down to measure the length and order the correct ones.
Old Feb 24, 2015 | 07:00 PM
HOUSE Motorsports's Avatar
HOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond reputeHOUSE Motorsports has a reputation beyond repute
For the 958 Cayenne - you'd want to look for:
Thread: M14x1.5
Seat: Ball
Head: 19mm hex
Thread Length: 36mm
- Jason
Old Feb 25, 2015 | 06:47 AM
mmdht2's Avatar
Thread: M12x1.5
Seat: Ball
Head: 19mm hex
Thread Length: 36mm
- Jason
thanks. this is most helpful.
Old Mar 2, 2015 | 11:39 PM
HOiYA's Avatar
HOiYA is infamous around these parts
For the 958 Cayenne - you'd want to look for: Thread: M12x1.5 Seat: Ball Head: 19mm hex Thread Length: 36mm - Jason
Jason,
Could you answer a question for me? If a custom wheel was "cut" for a lug bolt shank if 27mm, what does that mean? I would assume the 36mm length would be too long for the wheel. Also, would you but able to use 5mm spacers with the 36mm length in said wheel (27+5 < 36)?
Old Mar 3, 2015 | 11:07 AM
HoiYA - Typically the seller provides that sort of specific information on the specific set of wheels - but the only real way to see if the lug bolts will work is to have them measured out.
As far as using spacers go - as long as you have sufficient turns of the lug bolt after the spacer has been installed, you should be good to go.
Old Mar 3, 2015 | 01:06 PM
mmdht2's Avatar
can you look at a wheel to tell whether it's a cone or ball seat?
Old Mar 3, 2015 | 01:08 PM
mmdht2's Avatar
like the replica wheels, how do i know if they are ball seat like factory or cone seat like other aftermarket wheels?
Old Mar 3, 2015 | 03:12 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
Thread: M12x1.5
Seat: Ball
Head: 19mm hex
Thread Length: 36mm
- Jason
im pretty sure its M14x1.5, no Porsche uses M12. the only cars I can think of that uses M12x1.5 is the older mb's and bmw's.
Old Mar 3, 2015 | 03:14 PM
You are right - they are M14s! Had some old docs i was sifting through for that. Been corrected!
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
