Rear Dash Camera
Old Apr 23, 2015 | 06:14 PM
Always Up's Avatar
Always Up is infamous around these partsAlways Up is infamous around these parts
Rear Dash Camera
Hello fellow 958 owners!
I was wondering if any of you have rear facing dash cams. I was trying to plan a route for the USB cable but found problems in where to tuck it in, as well as where to mount it from the rear glass as the trunk opens quite wide which would make for very unsightly slack in the USB wire.
Prior experience would be great, pictures of your rear set up would be better!
Old Apr 25, 2015 | 11:23 AM
anakongkong's Avatar
anakongkong is infamous around these parts
Here is what I've did.
only remove trunk trip on that pics then put wier to that rubble. you need wire shielding like this link : http://www.stewmac.com/Pickups_and_E...iEOxoCKK_w_wcB
First time, I didn't shield my dash cam for rear, and I found dashcam 12V wire effect to remote key. so I couldn't lock/unlock the car in 3 meter....
so I used shield for that dash cam 12v, then It's solved. that's why I highly recommend using wire shielding.
then you can put wire like 2nd pics....
It's just 10-15min job.
Good luck!
Old Apr 25, 2015 | 02:19 PM
Always Up's Avatar
THANK YOU i really appreciate it
how did you slide the wire underneath the left rubber boot. Did you push it through from inside the trunk ceiling area?
Old Apr 25, 2015 | 02:27 PM
Just pulled down that ceiling trim. you don't need to remove whole ceiling. just little space and put your hand to grab wire that comes from top of sides.
Name:	resize_2015-04-24 16.03.29.jpg
Old Apr 26, 2015 | 05:13 AM
mjp911's Avatar
mjp911 is infamous around these parts
What camera setup are you guys using. How are you connecting it to the head unit or are you using a separate display?
Old Apr 26, 2015 | 08:52 AM
Robotpedlr's Avatar
Robotpedlr is infamous around these partsRobotpedlr is infamous around these parts
That looks like a BlackVue which has no display. Great system, I have the dr600 front mounted unit and love it (small and very stealth). You can view video on your iPhone (wifi) or put the chip in a viewer on your pc/Mac.
Jul 29, 2019 11:13 AM
007AMV8
Oct 19, 2015 09:55 PM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
Lifeisgood2
Aug 19, 2015 10:02 AM
