How to install an Aftermarket Amp with PCM 3
Old Mar 12, 2021 | 10:40 PM
anakongkong's Avatar
anakongkong is infamous around these parts
I believe the analog signals are sent out from the stock amplifier without cross-over. so that's why I just changed wire to RCA without crossover.
I'm not sure about the speaker in the front doors. I just replace them all
Old Mar 20, 2021 | 02:41 AM
LarsR's Avatar
LarsR is infamous around these parts
Thumbs up
Hello Anakongkong,
thank you for your great job and posts .
As I'm xxxx of the original ask amplifier (non-bose) (broken, and repair wasn't succesful at all) I would like to replace it with an aftermarket amp and continue using the PCM 3.1 headunit.
How do you get the wiring / connection from the oem plugs from the car / PCM to your amp. Did you do the wiring by yourself or are there any plugs / connectors avaible on the aftermarket?
Thank you in advance for your support !
BR
Lars
Bruce in Philly
Jul 13, 2016 10:39 AM
Steve Jarvis
Jul 22, 2012 11:13 AM
koen_dr
Cayenne 955/957
Jun 28, 2012 02:38 PM
gu9cci
Jan 19, 2010 10:21 PM
