New Fabspeed Quad Tips Installed!
Old Aug 27, 2015 | 05:47 PM
smartbot's Avatar
smartbot is a name known to allsmartbot is a name known to allsmartbot is a name known to allsmartbot is a name known to allsmartbot is a name known to allsmartbot is a name known to all
Just installed the Fabspeed Quad Tips (got a great deal from Vivid Racing - thanks guys!). The installation took a little longer than expected. I had a hard time fitting / aligning the tips... What do you guys think?
If anyone is interested I have my black powder coated tips available in the marketplace: https://www.6speedonline.com/forums/...ml#post4392041
Old Aug 27, 2015 | 07:11 PM
zracer196's Avatar
zracer196 is infamous around these partszracer196 is infamous around these parts
Hi. Sent you a PM but don't think these will work with standard S exhaust.
Anyone know?
Thanks in advance!
Old Aug 28, 2015 | 07:21 AM
Fabspeed Motorsport's Avatar
Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !
Anyone know?
Thanks in advance!
Correct, these tips only work with the PSE style muffler.
Old Aug 28, 2015 | 02:52 PM
kechang's Avatar
kechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to behold
considering your car is of a darker color, I much prefer the standard GTS tips but these are not bad!
Old Sep 2, 2015 | 07:06 AM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
Look great!
I love my Fabspeed tips too.
I understand what you mean.....install took longer than expecting.
They are so heavy that aligning them and tightening down is a bit tricky!
Old Sep 2, 2015 | 07:30 AM
jab23's Avatar
jab23 has a spectacular aura aboutjab23 has a spectacular aura about
I would usually say black looks better, but that looks great. Well done.
Old Sep 2, 2015 | 08:39 AM
cm09578's Avatar
cm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond reputecm09578 has a reputation beyond repute
I think they look great!
Old Sep 6, 2015 | 05:42 PM
zracer196's Avatar
Really like these...But will not work without the PSE exhaust...Bummer.
Not a lot of other choices out there for the non-PSE exhaust. Anyone have the Agency Power tips on a non-PSE Cayenne? If so post pics please...
Old Sep 7, 2015 | 07:05 PM
cjwal's Avatar
cjwal is infamous around these parts
If you do not have PSE, just go with the maxflo exhaust. It sounds great on my "s". Well worth it. I have had a ton of compliments on the sound. Including every time I take it to my dealer.
Old Sep 7, 2015 | 07:15 PM
zracer196's Avatar
Thanks CJ.
Do you think the Maxflo over the bypass pipes?
What will yield the better sound? I would rather not spend the money on both.
Thanks in advance!
Old Sep 7, 2015 | 07:33 PM
cjwal's Avatar
Definitely the maxflo. No drone great deep sound. It won't give you the GTS gurgle, but it sounds great. For me I didn't need the cat bypass. It's still a DD for me.
Old Sep 8, 2015 | 07:13 AM
Thanks CJ.
Thanks in advance!
As cjwal said the maxflo mufflers are a great option that provides an awesome more aggressive sound! To gain some additional power and sound, the secondary bypass pipes are a fantastic addition!
Please check your PM's
Old Jul 14, 2017 | 09:08 PM
MayorMcCheese's Avatar
MayorMcCheese is infamous around these parts
I may have to consider this secondary bypass pipe
I don't want this mod to be known on my CS so if at any time I had an issue with my cayenne id swap it off.. I could probably do this myself with an airgun and the air suspension raised and on some rhino ramps
http://www.fabspeed.com/porsche-958-...tbypass-pipes/
Old Jul 14, 2017 | 09:22 PM
BlazinPond's Avatar
Airgun is not going to work. Very tight access to remove the bolts.
If you search, i created a DIY article here somewhere.
Jun 10, 2017 07:45 PM
John@SpeedTech
Aug 23, 2015 12:07 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
