DIY - 958 PCM3.1 Video Interface and Android Module Installation
Old Oct 11, 2016 | 05:59 AM
ohnoyuji's Avatar
ohnoyuji is infamous around these parts
Originally Posted by ddaarr
Very awesome and impressive. I always felt the Porsche interface was lacking.
Yup, even the new Porsche Interface is not impressive.
But the new Capacitive Screen is much better than ours, faster and more accurate.
Old Oct 11, 2016 | 08:56 AM
ddaarr's Avatar
ddaarr is infamous around these parts
Any link to the android module and the video interface. $500 sounds reasonable.
How do you adjust the sound/ fade/ balance and so forth via the android screen?
Old Oct 11, 2016 | 09:47 AM
ohnoyuji's Avatar
They still sell them here: Porsche-Aliexpress-Lsailt.
The sound/fade/balance is still from the original head unit, press the "Car" button, it will switch out of the Android.
Old Oct 11, 2016 | 10:42 AM
ddaarr's Avatar
Thank you for the link. What steering controls work/ don't work with the new modules installed.
I'm getting convinced this is the way to go.
Old Oct 11, 2016 | 10:58 AM
ohnoyuji's Avatar
The android sound output will need the car AUX input, you will need an Stereo RCA to 3.5.mm stereo cable. Don't expect surround sound will work if you a audiophile. All the cables comes from the seller are marked, but only in chinese.
All the steering control works, but doesn't change track while in the Android mode. But will work again, once switch out, in the factory interface.
Volume roller, mute, mode, all works.
Old Oct 14, 2016 | 08:56 AM
ddaarr's Avatar
Please post a short video of switching between the Porsche interface and the Android interface.
Just curious, what are you plugging into the Video interface if you are using the Android module to watch youtube?
Old Oct 14, 2016 | 09:35 AM
ewenc126's Avatar
ewenc126 is infamous around these parts
Great
Thanks for reply, I did order from the link you provided, just wait for my new toy.
Old Oct 14, 2016 | 09:37 AM
ddaarr's Avatar
Its on sale for $485 instead of $510.
Old Oct 14, 2016 | 09:39 AM
ddaarr's Avatar
Im ordering the Video and android module today. Are you planning to install yourself? Im in San Jose.
Old Oct 14, 2016 | 10:40 AM
ewenc126's Avatar
Yes I am planning install by myself, I hope easy to do that.
Old Oct 17, 2016 | 11:29 AM
ddaarr's Avatar
Can anyone recommend a front camera? That would be helpful parking into my garage.
Old Oct 17, 2016 | 11:43 AM
ohnoyuji's Avatar
Sorry I sold the car already back in August. Can't really find another video for you.
But I kept the android module.
I have bought an ATSC 20$ Sylvannia tv box. It works! But only stationaary.
If you can find a ATSC-M module, you can hook that on, watch tv while driving (for passenger)
Old Oct 17, 2016 | 11:49 AM
ohnoyuji's Avatar
Make sure you pull the CBs (Fuse) of the headunit before you do anything with the headunit and grounding.
The car still feeds power even with car off for a good 15minutes.
When you take out the original headunit out, there are quite a few tabs and screw that you need to open. THey are quite tough, you need to be gentle but also strong finger to do this. Pry using a flat screw driver will work.
And there's two temper proof seal as well. (void factory warranty)
Just becareful when you hook the two new ribbon cable. they are quite fragile I found.
And, ground yourself before you do anything inside the headunit.
I've also succesful installing the backup camera, however, the car original came with a "Solder" on switch, I didn't had the patience to resoldering it.
I left the switch un-operable.
Too bad, I sold the car in August.
But I can provide tips when you guys gets the material.
Old Oct 17, 2016 | 11:52 AM
ohnoyuji's Avatar
The switch module has the front parking camera input, but I can't really find any good camera that is rock proof, it will look very ugly and non-oem.
I haven't seen any oem look on aliexpress or ebay before I sold the car.
Old Oct 17, 2016 | 11:44 PM
ddaarr's Avatar
If I'm streaming music via Bluetooth on the OEM Porsche interface, can I use the Android module for navigation with music at the same time?
Or will the music from my phone cut off?
Or can I stream music via Bluetooth from the Android module and have navigation going on at the same time?
It's so confusing.
