Oil pressure issue, cayenne 958 212000 Km
Old Feb 21, 2016 | 01:01 AM
khalil958's Avatar
khalil958 is infamous around these parts
Question Oil pressure issue, cayenne 958 212000 Km
Hi all
my car is porsche cayenne 2011,
so when i start the car from cold, normally the oil pressure will go to 2.0 bar, then will fall to 1.6 bar and this is normal since i bought the car from the dealer
while now, when i start the car from cold, the oil pressure will go straight away to 2.8 bar and stays there what ever i do, and only falls back to normal when i drive the car and oil temp will go to normal ( 100 C )
any idea what is going on, my friend told me it is an oil pressure regulator solenoid that is not functioning very well??
thanks
Khal
Old Feb 21, 2016 | 11:15 AM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Changed oil lately? Perhaps the wrong weight was put in?
Old Feb 21, 2016 | 11:57 AM
khalil958's Avatar
I changed the oil before 9000 km, always been using the same oil, but i will give it a go
Old Feb 22, 2016 | 10:15 AM
I watched mine today ('11 Turbo) - and starting from cold (around 50F in the garage) - on acceleration it reached 3Bar. Under steady state (perhaps 1,800 RPM) it was at 2.5-2.8Bar. When the car warmed up a bit (oil still showing as cold) - probably 2.3-2.5Bar at 1,800 RPM.
I don't see anything scary about the numbers you're mentioning and they well might be entirely normal. 1.6Bar = ~24PSI. 3Bar=~45PSI. That seems a quite normal range and I wouldn't be concerned. If it pegged the gauge - then I'd be concerned.
avman2cl
May 9, 2016 08:45 PM
Jett911
Apr 18, 2016 04:40 AM
958TT
Mar 25, 2016 11:20 AM
majd1239
Mar 10, 2016 12:38 PM
