Default Transmission related durametric fault codes. Any help?
Old Jun 7, 2016 | 09:58 AM
Nixer's Avatar
Nixer is infamous around these parts
Tiptronic Transmission
Current Fault Codes 3277600 / 320320:
Warning Indicator Off
Test Completed This Monitoring Cycle
Test Not Failed Since Last Clear
Test Completed Since Last Clear
Not Pending DTC
Test Not Failed This Operation Cycle
Fault Passive
P093100: Gear Shift Lock Solenoid Control Circuit High Factory Fault Code 12755
Not Pending DTC
Fault Passive
P189000: Signal wire for Tiptronic Electrical malfunction Factory Fault Code 12791
Not Pending DTC
Fault Passive
P0C2D00: Auxiliary Transmission Fluid Pump Control Module Feedback Signal Low Factory Fault Code 12800
Warning Indicator On
Test Failed Since Last Clear
Pending DTC
Test Failed This Operation Cycle
Fault Active
Can someone help me interpret this durametric codes. Fault Passive means it's not longer active but registered? Where is the auxiliary transmission fluid pump control module? Is it referring to DME?
This is really scary...this car was in an accident and it starts just fine.. but too many fault codes.. and yes, I have check engine light on.
Old Jan 27, 2017 | 01:35 PM
Dominicansensacio's Avatar
Dominicansensacio is infamous around these parts
I have a 2012 Cayenne v6 and engine light also came up. I got the similar error codes. nothing different on the way the car performs. I took a round trip 260-300 miles roadtrip and literally as i get home, i fill up my gas get a carwash to get rid of all the bugs. Then at start up engine light didn't come back on. Weird i purchased durametric cable and it seems as if code is still in the system with no engine light. So i wonder...
Wildcat1212
Jun 17, 2016 11:26 AM
tommyboy214
Apr 4, 2016 07:31 PM
charlie1
Mar 30, 2016 08:07 PM
Markblackwell
Mar 30, 2016 09:44 AM
chiapet15
Cayenne 958
Mar 24, 2016 04:40 AM
