Auxiliary Transmission Fluid Pump Control Module Location???
Old Jul 12, 2016 | 08:28 AM
Nixer's Avatar
Nixer is infamous around these parts
Auxiliary Transmission Fluid Pump Control Module Feedback Signal Low Factory Fault Code 12800
I have this fault on my car along with shift solenoid faults. Does anyone know the location of the auxiliary transmission fluid pump?
Can a faulty gear shift solenoid trigger Check Engine light?
P093100:
Gear Shift Lock Solenoid Control Circuit High Factory Fault Code 12755
Warning Indicator Off
Test Completed This Monitoring Cycle
Test Not Failed Since Last Clear
Test Completed Since Last Clear
Not Pending DTC
Test Not Failed This Operation Cycle
Fault Passive
P093100:
Not Pending DTC
Fault Passive
P189000:
Signal wire for Tiptronic Electrical malfunction Factory Fault Code 12791
Not Pending DTC
Fault Passive
P0C2D00:
Warning Indicator On
Test Failed Since Last Clear
Pending DTC
Test Failed This Operation Cycle
Fault Active
Old Jul 12, 2016 | 12:51 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Are there any problems with the truck?
Have you cleared the fault codes to see if they come back?
Before troubleshooting what may not be a problem, it's worth doing both of those items.
Old Jul 12, 2016 | 01:56 PM
Nixer's Avatar
I have the check engine light on.. There are no other faults to see. I cleared all these codes and drove a bit. All these codes came back on. So I guess there is a problem.
Old Mar 21, 2019 | 04:24 AM
DM27's Avatar
DM27 is infamous around these parts
P093100:
Not Pending DTC
Fault Passive
P093100:
Not Pending DTC
Fault Passive
P189000:
Not Pending DTC
Fault Passive
P0C2D00:
Pending DTC
Fault Active
Hi Mate, did you find where this module located? I have changed gearbox oil about 3000 kms ago and now I have check engine light and error: P0C2D00: Auxiliary Transmission Fluid Pump Control Module Feedback Signal Low
Old Jun 2, 2019 | 07:52 PM
nitrorocket's Avatar
nitrorocket is infamous around these parts
It's underneath the passenger seat directly under the TCM.
Old Nov 18, 2019 | 10:26 AM
sjg1138's Avatar
sjg1138 is infamous around these partssjg1138 is infamous around these parts
Has anyone figured out how to deal with the Auxiliary Transmission Fluid Pump Control Module Feedback Signal Low error message ? Does replacing the Module solve this or is is an issue with the Pump itself?
A part number for the control Module would be really helpful if you happen to have it.
Cheers
Old Jan 2, 2020 | 12:55 PM
Scrotius's Avatar
Scrotius is infamous around these parts
There are two modules under the passenger seat (under the carpet) which is the TCM and the Oil pump module:
Oil Pump control module part number: 7P0 927 601
Not sure if this is the specific oil pump control module you are looking for, but that's the one which is under the passenger seat.
coincidentally, this is also in a place where if you get any water in the passenger side foot well, the wiring and module itself will be highly susceptible to damage...
Hope this helps.
legendrx7
Cayenne 955/957
Aug 7, 2024 04:51 PM
Scrotius
Dec 14, 2019 09:58 PM
Dav1992
Bentley
20
Sep 9, 2019 07:53 AM
Nixer
Cayenne 958
Jan 27, 2017 01:35 PM
