2011 CS instrument cluster light gone.
Old Jul 2, 2017 | 01:23 PM
cayguy0521's Avatar
cayguy0521 is infamous around these parts
Hi, my 2011 cayenne instrument cluster light gone thus seat memory, side mirror, signal light and other stuff not working. I called dealership and they told me I have to replace something on back of the car and it costs minimum 3k. I just checked to see if it cause by fuse so I checked fuse and it looks fine. When I plug fuse back in right position light comes back and it worked fine after three days, but it went off again. It happened couple times and I am pluging the fuse all the time to work this. What might be the problem of this issue? Anyone has same problem??
Old Jul 4, 2017 | 09:10 PM
bonnie sacer's Avatar
bonnie sacer is infamous around these parts
no. sounds pretty weird.
Old Jul 4, 2017 | 09:19 PM
cayguy0521's Avatar
it is weird... Maybe the battery?? My CS is 6 years old with 52000 miles on it. I did not drove that much.
Old Jul 5, 2017 | 08:49 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
A new battery won't hurt anything. And I can imagine a situation where the battery voltage drops low enough during cranking that the cluster turns itself off to prevent a low voltage melt-down.
