LED Licence Plate Bulbs
Keep us posted RickDC. Looks like you're doing what kechang had outlined in his post(which is in the DIY section). I'm not an electrician but looked at the schematic on the Philips LED warning canceller and it looks like the brown(negative) and grey(positive) wire just clip into the red plastic parts and that's it? It doesn't look like you have to snip any wires am I right?
If this is the case, I'm definitely within my comfort zone on this one.
I'll probably stick the Philips resistor to the metal part inside the trunk (reaching through the license plate socket as it will get hot and don't want it to affect the plastic / paint on the lid. It will be delivered on Wed, so I'll keep you guys in the loop!
Thanks for your write up kechang. Interesting to note that in your write up from 2014, you referenced the OEM LED license plate lights. Looks like you got them from ECS tuning but when you go to their website I don't seem to be able to find them.
I'll be interested to see how RickDC's lights turn out. In the meantime, I went with the AZNOptics W5W 5000k LED bulb v5.2A and I can confirm there is no bulb out error. I think they look great!
Kechang, did you ever find an LED solution for the puddle lights on the side mirrors? I read they could be replaced by taking off the side mirror only(not the black housing behind) but there was no way I could get my fingers in there! Were you able to go LED there and if so, what did you use?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
https://www.ecstuning.com/b-genuine-...k8943021c~por/
also, I ordered my car with the extended LED package so everything is LED already except the license plate light, so I fixed that myself
I believed I've seen some member replaced them with instruction, so do a search on that
Retrofitting
unfortunately, Kechang’s retrofitting dadn’t work for my 2012 Cayenne S, I broke one of the pins because of many failure attempts of reversing the wire so I ordered new pins and socket from ebay.
The easiest way to get OEM number plate ( many thanx to Kechang ) I got a lot of him, however I’d like to add more information.
What you need to do is to buy the following:
1- 1k8943021c (VW LED lights)
2-12956X2 ( 12 v philips canceller)
3-1j0973702 (make sure pins included for each side) very cheap on Ebay
no need for the pin extrator which I spent over a month to bring it from USA to Saudi Arabia : )
now you can just cut the wires from the stock housing and and plug the new pins 1j0973702 make sure to tighten the pins on wires and test them before you plug them check if it is removeable dont plug them, and then it will definitely be working in 10 minuets.
Make sure to put the brown wire inside number 1 of the housing not number 2, just swap them.
Please visit Kechang post before doing any of these instruction
https://www.6speedonline.com/forums/...ree-way-4.html
haha it's cheap enough to buy at local porsche dealers
