GTS/21" tire pressure advice pls?
Old 02-16-2018, 08:21 AM
bzliteyear's Avatar
bzliteyear is on a distinguished road
Hi all,
Sorry if I posted to wrong forum earlier, but I'm trying to figure out the best tire pressure for maximum tire wear for my 2013 Cayenne GTS w/ 21" wheels.
I've had the car for 6 months and it's been at 32/38 lb front/rear.
However, the door indicator was much higher - closer to 40/48.
Can those of you who have owned Cayennes for a while share your thoughts?
Thx in advance.
Patrick
Old 02-16-2018, 04:56 PM
e30rapidic's Avatar
e30rapidic will become famous soon enoughe30rapidic will become famous soon enough
I use 42 psi all around, 2013 GTS w/21" sport wheels
Old 02-16-2018, 05:54 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
For max mileage - use the chart above and pick "Full Load" values. You may loose some comfort and handling using those settings though, but since you're looking specifically for maximum mileage I can only assume that's the priority.
Old 02-16-2018, 11:41 PM
TJtheDJ's Avatar
TJtheDJ will become famous soon enough
I was always curious as to what constitutes a ‘part load’? Is that if your a single driver not carrying around a family most of the time?
Old 02-17-2018, 11:40 AM
I think that's a pretty accurate description. FULL LOAD is when SWMBO and I drive to California.. and back.. it's when nothing else will fit in the rear trunk part, and the back seats can't be seen.
CodeBlue911
Cayenne 958
10-24-2015 08:05 PM
nanoc15
02-24-2014 12:24 PM
cole328
05-09-2013 12:40 PM
MTRX
Cayenne 955/957
09-18-2009 08:42 AM
trovan
Wheels/Tires
09-17-2009 01:43 PM
Quick Reply: GTS/21" tire pressure advice pls?
