Headlight Gaskets for 2011-2014 958
Old Apr 18, 2018 | 08:06 AM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Here what the 3/16" seal much better test fit (no adhesive reason for slight bulge at the top). Not happy with the temp range, I may let them go through the summer and see how it holds up.
Looks like I'm doing some paint correction soon.
Old Apr 18, 2018 | 10:09 AM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Jay - looks great. How much is the seal per foot?
Old Apr 18, 2018 | 10:29 AM
jayi836's Avatar
Hey Don-Here's the link, and perhaps the easiest repair ever, spent more time dorking with the dam electrical connector, trying to get it off without scratching the bumper. Yes I used a small screwdriver to release the tab. one side just wouldn't let go.
Get the bottom one for $1.28 per foot.
Available in red if you like P!G eyeliner? High temp and 1/4" version
You will need 7 feet however have to by 10 feet. I'm still looking for a high temp solution if anyone knows where to source it from.
I plan to take a temperature reading on the next 100+ degree day.
https://www.mcmaster.com/#catalog/124/3588/=1cgurj9"]https://www.mcmaster.com/#catalog/124/3588/=1cgurj9
Old Apr 19, 2018 | 03:59 PM
Jay - further down the page they list some made from Viton - which is generally a longer lasting more chemical resistant rubber - might do better at resisting ozone breakdown. Of course it's several times the price.
Old Apr 20, 2018 | 10:35 AM
jayi836's Avatar
Don- I ordered some 1/4"Viton PN: 2072T11 yesterday the product rated as "hard" vs the medium hardness. Ill deal with the slight bulge at the top by a small slit on the back side.This may make it lay flatter at the radius point.
The factory seals are not "bulb type" so the contour better around curves.
Old Apr 20, 2018 | 06:48 PM
Jay - be interested in seeing how it looks installed.
Old Apr 24, 2018 | 11:27 PM
jayi836's Avatar
Here's the Viton seals in action
no adhesive needed, however I added a drop at the bottom far outside corners as there was no tab available.
a few spots on one headlight need a little trim from excess lens sealant.
No more than a 30 minute job.
Update: The gaskets are available here https://www.mcmaster.com/#2072t11/=1cnqh2l (thanks Don)
Select other quantity and purchase 7', this will save some money. I ordered 10' without paying attention to all the options.
10' of Viton seal
Notice the lip on the lens
curve at the top
marked the holes with paint marker then punched them
holes made
release mechanism decided to come off with tool
Back in its place don't want the headlight to fly out (pre-recall)
will post some more photo's after i get the car detailed
Old Apr 25, 2018 | 08:15 AM
Jay - wow! VERY nice job. Excellent. Can I persuade you to do a DIY for rennlist's Cayenne forum?
Don
Old Apr 25, 2018 | 08:28 AM
jayi836's Avatar
Don- Feel free to distill this down and use the images over at rennslist. I'm not Ernest Hemingway :-).
Another member did that with the window shade repair I did last year.
It would also help if my 958 wasn't black.
Old Apr 26, 2018 | 05:24 PM
Macporsche015's Avatar
5 Year Member
Macporsche015 is infamous around these parts
Excellent project, I like it better than the rings. Where in So Cal are you located?
Old Apr 26, 2018 | 07:54 PM
jayi836's Avatar
[QUOTE=Macporsche015; Where in So Cal are you located?[/QUOTE]
Simi Valley,Ventura County. Formerly the safest City in America
C4SxM5
Mar 8, 2018 10:16 PM
austinhuffzz
Apr 7, 2016 08:11 AM
poundsan
Nov 28, 2015 08:26 AM
BlazinPond
Cayenne 958
Dec 28, 2014 09:14 AM
TT VIPER
Cayenne 955/957
22
May 9, 2014 01:34 AM
