2013 958 Cayenne S Transmission Slipping
Old Apr 3, 2018 | 04:25 PM
Targa4sg550's Avatar
Targa4sg550 is infamous around these parts
None
Old Apr 3, 2018 | 06:03 PM
garrett376's Avatar
garrett376 is infamous around these parts
Sounds fair if you're willing to pay for it. But I'd spend my money on a proper diagnosis which would likely lead to discovering that you need a new transfer case and your transmission is just fine.
Old Apr 3, 2018 | 06:50 PM
None
Old Apr 5, 2018 | 08:35 AM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Agree entirely on the transfer case being the issue. I have not heard of a single transmission failure on the 958 series cars.. it seems ZF can make transmissions that are reliable, they just have a little problem with transfer cases.
Old Apr 5, 2018 | 10:10 PM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
How may miles?Mine may be a fluke just flat out died at 127K, I would lean toward the XC also, Have the dealer diagnosis the issue.
Old Apr 6, 2018 | 08:51 AM
Interesting - now I have one confirmed transmission failure - at high miles. The replacement is about half what I expected Porsche would charge..
Old Apr 6, 2018 | 05:43 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
Targa and Jay.
Difficult expenses. Thanks for sharing.
Did either of you change the trans fluid since ownership? Just curious if original high mileage fluid caused the premature failure.
Old Apr 7, 2018 | 11:47 AM
e30rapidic's Avatar
e30rapidic is infamous around these partse30rapidic is infamous around these parts
Originally Posted by mto
Targa and Jay.
There have actually been quite a few success stories of a fluid change fixing the transfer case slippage. Make sure you use the Porsche stuff, only takes 1 bottle. Its about $50 and can be completed in under 1 hour.
Fingers crossed that will fix it for you!
Old Apr 7, 2018 | 01:35 PM
mto's Avatar
mto
Actually,meant the ZF transmission, not transfer case.
Had any of these had their ZF trans fluid changed well before these repairs?
TIA.
Old Apr 7, 2018 | 01:38 PM
jayi836's Avatar
Targa and Jay.
Joseph,
I'm the second owner, purchased after the the engine and transmission was replaced. I plan to replace the fluid soon. I have almost 40K on the second unit.
I doubt the original fluid was changes as Porsche states 16 years/160,000 miles.
Old Apr 7, 2018 | 04:48 PM
mto's Avatar
mto
Originally Posted by jayi836
Joseph,
Thanks. I just don't get these extended changes over 100K miles, no matter how great the fluids are and tolerances these days. Maybe it's a generation thing with me, but am sensitive about the environment.
bull30
Aug 3, 2016 02:04 PM
BlazinPond
Cayenne 958
Dec 28, 2014 09:14 AM
motoadve
Cayenne 955/957
Dec 10, 2012 12:08 PM
