Cayenne Turbo All Cayenne Turbo model topics
Video: Wicked Cayenne Turbo w/ Bolt-ons - Dyno ~ 675 hp / 710 tq [HD 1080P] [Graph]
Old Jul 13, 2013 | 08:00 AM
  #31
bonemechanic's Avatar
bonemechanic is infamous around these parts
Renaissance Man, I have a 2006 Turbo S and am about to venture down this path. So far I have done some of the bolt on's. (IPD Plenum, 2nd Cat Del) Car still is a little sluggish (after my GTR). Want a bit more. Do you have any tips for someone?? I tried to call/talk to the guys at Leistrung but can never get anyone on the phone or a call back. I was thinking on using their primary delete pipe and exhaust.
Old Jul 14, 2013 | 09:18 PM
  #32
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
From what I understand, Rob from Leistung is putting a hold on new business since he has other matters that is demanding the majority of his attention.
Are you aware that the 955 (2006) CTTS is a different engine than the 957 CTTS that I have? Though I am sure the gains would be similar, I cannot vouch for them personally. With that said, I would say your best bet to get out some of the lag is to get an EVOMS air intake, diverter valves, ECU tune, and primary / secondary cat bypass pipes. I also happen to like my Sprintbooster since it helps with more aggressive throttle mapping and TCU learning algorithm.
Old Jul 14, 2013 | 10:42 PM
  #33
jasonsowers's Avatar
jasonsowers is infamous around these parts
At the crank? Could I see what the car puts down at the wheels?
Old Jul 14, 2013 | 10:46 PM
  #34
Moderator
It sounds like you did not check out the dyno on the very first post... or the video of the dyno session (also located in the first post).
Old Jul 14, 2013 | 10:47 PM
  #35
Got it. I didn't see the hot link. Looks good. Are you running water/meth?
Old Jul 14, 2013 | 11:15 PM
  #36
Moderator
Nope. Wanted to bump boost a little up to 20 psi and run meth to compensate. Had a talk with Softronics and was told that in order bump boost, I would have to get a standalone boost controller. Didn't want the additional exposure risk on a DD for the boost controller and found it hard to justify the meth injection alone for just the small bump in Octane and lower air temps. Wanted the pretty package deal with factory value management. However, it doesn't look like a valid option.
Old Jul 14, 2013 | 11:23 PM
  #37
Meth would really wake that truck up.
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
