Cayenne Turbo All Cayenne Turbo model topics
upgraded turbos for 958
Old Aug 30, 2015 | 10:03 PM
SI-CO 13's Avatar
SI-CO 13 is infamous around these parts
Hi everyone. I am kinda in need of some help. I have been trying to find some info on doing a turbo upgrade. Also would like to upgrade the intercoolers. Are there any kits available? I am not really concerned about the cost. More concerned that the upgrade is done correct and with the best parts possible. I have been searching the web for weeks and I just cant find anything.
Any help would be MUCH appreciated.
Thank you
Old Aug 31, 2015 | 07:34 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
You need full exhaust , or at least downpipes and secondary cats
- forged or agency diverter valve
- turbo S intake manifold with ipd plenum
-bmc air filter
- upgrade oem turbocharger from td0hl-18T to 20T at ard or fvd .
- if you choose ard you need a custom tune , on dyno at a good tuner . Fvd has tune for panamera but I dont know about 958.
Panamera owners have been pushing 700-750 hp with limited 700lb/ft torque , I guess tiptronic can take 800lbft so I am interested to see your numbers.
Old Aug 31, 2015 | 08:39 AM
SI-CO 13's Avatar
-bmc air filter
Thanks. Yes I already have every mod. Just dont have upgraded turbos or intercoolers. Still want more out of it.
Old Aug 31, 2015 | 02:00 PM
SI-CO 13's Avatar
Also how much HP are the stock intercoolers good for?
Old Sep 1, 2015 | 12:55 AM
I do not know , but bigger turbocharger will produce more with less boost and heat , so I guess you will be fine
Old Sep 4, 2015 | 11:41 AM
SI-CO 13's Avatar
It is at all possible to do a turbo swap with the motor still in the car?
Old Sep 8, 2015 | 07:15 AM
Looks like you can , by removing front axle with wheels and remove engine arm to lower the engine just a couple of cm .
Old Oct 8, 2017 | 02:37 PM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Did you ever get the turbos upgraded?
Mackchacha
Jul 9, 2019 11:03 AM
vr6tee
Aug 29, 2015 03:52 AM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
Vrseis
Aug 20, 2015 07:41 AM
