Video: How To Change The Brake Pads And Rotors On A Cayenne Turbo
If anyone needs help changing the rear brake pads and rotors for their 1st generation Cayenne Turbo, I made a how to video that will hopefully be helpful. This video should apply to all 2003-2006 Cayenne Turbo's.
Good video. Just be carful leaving your car jacked on a hydraulic floor jack. They can fail. I have a 2008 Turbo and unfortunately I am going through the painful process of trying to get the right parts for my vehicle. I got lucky and got the one year of Cayennes that couldn't make up there mind with brakes. Between a 368mm front rotor, finding the right pads that will work and having calipers that you have to pull off to replace the pads. Makes it frustrating and constant runs to the local shop which has left my CTT on blocks all week.
Good job. I'd second the always use jack stands comment though, especially if any part of you is going to be under the car.
The caliper bolts should also have a bit of thread lock on them. One more reason they are so hard to get out. Mine has the big brake package and the front ones were even harder. I ended up heating the bolt with a heat gun then still resorting to the breaker bar with a sledge hammer.
One more trick I use is to stick a big screwdriver between the rotor and old pad before removing it to compress the caliper back down. Especially on multi piston calipers like this sometimes when you push one down the other will pop back up. Just makes it a bit easier.
There were a lot of permutations of brakes on these things for several reasons. It took me awhile to sort mine out too. My 2005 has the big brakes with 380mm two piece front rotors which nobody seems to make aftermarket. $2,500 in parts to do mine and about $1800 of that was just for the two front rotors.
There is a jack stand under the car as a safety precaution but it doesn't look like it shows up in the video. I have one to the left of the jack and also under the rear diff. I swap them depending on what area of the car I'm working on.
Don't you just love Porsche for that? I even had difficulty finding out the right size rotors I needed. There seems to be some conflicting info on what size rotors even my 2005 Turbo has. A quick call to the dealer got that sorted out (330mm for my 05' Turbo).
Enclosed is a good cheat sheet I found on what size rotors our cars came with.
WOW! I will consider myself fortunate then. In the end I'll have spent $800 for front and rear drilled and slotted rotors with yellow stuff EBC pads. I could of done it for about $500 but I really wanted to get drilled and slotted because they look so much better with my 22's.
Isn't yellow stuff brake pads their "race" offering? If so, I would stick with the red stuff pads much better for street and you won't be squealing at every stop sign. lol
Yellow stuff is actually their SUV, 4x4, truck brakes (Heavy Cars). Couldn't find the right red or green stuff brakes. It appears that they were yellow stuff pads on my car previously too. Don't think they make the Red Stuff (Race) pads for my Cayenne.
Nice calipers! Love the color. Who painted them?
The cheat sheet is a good base to start with. But like with mine, it has the iE81 upgrade so has the big 380mm two piece front rotors. That's why I was saying there were many permutations of brakes on these things. Leave it to Porsche to complicate something as simple as brakes.
People always have a hard time believing my brakes cost as much as I said so I show them this page. Notice the only major difference between the standard and iE81 brake kits is essentially the two piece front rotors and about a $2,200 difference in price https://www.ecstuning.com/Porsche-20.../Service_Kits/
I was thinking I had put Red stuff on mine but looking again at the ECS page I posted above they show yellow stuff in the kit too. Whatever they are they create WAY less dust than whatever was on it when I bought it. Incredible difference.
Thank god mine doesn't have the E81 kit! Yikes! $2200?
Well the bad news is after I did my brake job I lost the security lug. Knowing Porsche I'm sure a replacement is the cost of a first born.
