Cayenne Turbo All Cayenne Turbo model topics
Everyone welded X-Pipe in OEM Stock Exhaust (957 CTT) ?
Old Jan 17, 2019 | 03:05 PM
TurboChristian's Avatar
TurboChristian is infamous around these parts
Exclamation Everyone welded X-Pipe in OEM Stock Exhaust (957 CTT) ?
Hi,
I'm Christian from Germany and i drive a 2008 CTT. (957)Now I have removed the secondary catalysts.
Now I'm thinking about assigning an X Pipe as it is with various accessories exhaust Systems. Has anyone already done this with the original series exhaust?
Based on pictures of different sport exhaust manufacturers, the position is quite clear.
But does it make sense with the turbo engine or I lose thereby only achievement?
maybe you can write your experiences if you noticed a positive effect.
Greets Christian
(sorry for my English)
Old Mar 8, 2019 | 07:45 AM
marinerbc's Avatar
marinerbc is infamous around these parts
Originally Posted by TurboChristian
Hi,
Greets Christian
Hello Christian,
I would not do the X pipe on the CTT V8, the exhaust pulses are already balanced and more importantly there are two cylinders on each bank that has their exhaust v/vs lift
more than the other two. so exh. v/vs for :-
Cylinders 1,2,6 and 8 lift = 8 mm
Cylinders 3,4,5 and 7 lift = 9.2 mm
X98boardwell
Mar 23, 2016 03:07 PM
cm09578
Aug 28, 2015 08:05 PM
007 Vantage
Dec 26, 2010 03:08 PM
VAGscum
Nov 7, 2010 04:42 PM
