California members: Passing emissions with aftermarket exhaust?
Old Jan 11, 2011 | 08:16 AM
X98boardwell's Avatar
X98boardwell is infamous around these parts
I realize no aftermarket exhaust will be CARB certified. My concern is if it will be clean enough to pass... meaning not producing more pollutants than allowed.
I just purchased an Agency Power exhaust with 200 Cell cats. Any experience out there with this exhaust in California?
Thanks,
Bryan
Old Jan 11, 2011 | 09:42 AM
msidrd's Avatar
msidrd is a splendid one to beholdmsidrd is a splendid one to beholdmsidrd is a splendid one to beholdmsidrd is a splendid one to beholdmsidrd is a splendid one to beholdmsidrd is a splendid one to beholdmsidrd is a splendid one to behold
I have a FVD system with 200 cell cats on my '03TT with no issues passing smog.
Old Jan 11, 2011 | 09:58 AM
OCTurbo's Avatar
OCTurbo is infamous around these parts
you should be fine with 200 cell cats. my speedtech exhaust with 200 cell cats past without problems in ca. we have an advantage with the all wheel drive, because they can put the car on the rollers.
Old Jan 11, 2011 | 12:19 PM
Guys, thanks for the help. I plan on adding the new exhaust this weekend. Should I replace the gaskets for the exhaust where it meets the turbo on my car.... It has only 9000 miles.
Thanks,
Bryan
Old Jan 11, 2011 | 02:01 PM
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
I passed with Speedtech full system with 100 cell cats and an EPL tune... No issues whatsoever....
Old Jan 11, 2011 | 08:40 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Passed with flying colors with my Milltek 100 and it has >15k on it. You can run the car for 30mins ahead of time to heat up the cats... Hear this helps things out.
Good luck!
Old Jan 11, 2011 | 10:18 PM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
I have the EVO Milltek exhaust with 100 cell cats and it passes smog with no problem.
Old Jan 12, 2011 | 01:27 AM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
I hear you can reuse the gaskets off your stock exhaust, and that these stupid thin metal rings are really expensive. Some one correct me if I'm wrong, but I don't think I am.
Old Jan 12, 2011 | 02:33 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Yes they are stupid expensive about $75 a pair.
Old Mar 29, 2015 | 06:41 PM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Bumping an old thread here...
1. 100 octane will probably throw the sniffer test? Probably need to use that up...
2. I have 200 cel cats -- but not OEM exhaust on car. Will they auto fail me in CA?
Thanks!
Henry
Old Mar 29, 2015 | 06:58 PM
Duane996tt's Avatar
California does not use a sniff test anymore. They read out your ECU. California has also had a visual inspection test also. Most tunes will not trip the ECU test. As far as the visual inspection, you just have to find the right smog inspection station.
Old Mar 29, 2015 | 07:01 PM
Duane996tt's Avatar
As long as its cat back, there should be no issue.
Old Mar 29, 2015 | 10:31 PM
Road King's Avatar
Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !
Thanks!
Henry
If you go to a random "non friendly" smog testing station they can fail you on visual, regardless of the actual emissions test or new ECU scan test.
Best bet is to go to a known 'friendly' smog check where they will overlook any shiny exhausts etc.
Old Mar 29, 2015 | 10:43 PM
vr4henry's Avatar
Interesting, so I guess I just try to get lucky and hope he doesn't get too far under car. It's not very loud at idle.
Maybe borrow a stock 996TT exhaust and go back if I have to. What a hassle for a car that would pass the freakin' sniffer no problem, hah.
Old Mar 29, 2015 | 10:57 PM
BlueDream996's Avatar
BlueDream996 is just really niceBlueDream996 is just really niceBlueDream996 is just really niceBlueDream996 is just really nice
It's a pain in the a** to get smogged once you get flagged with not passing for whatever reason.. I just went through all of this, and I have some info in my car thread.. If I were you, I would ask some of your car buddies for a mod friendly smog station before rolling the dice..
