Just installed my modified stock exhaust....
I had an extra stock exhaust laying around and decided to play a little. I gutted the 400 cell secondary cats and drilled a 2" hole in the back of the curved tube(per modified stock exhaust thread). I did this so that the car would sound a little better and hopefully had a little better turbo spool from the gutted secondary cats. I know that gutting both would have probably been better, but I still have to consider emissions here. The secondaries are supposedly the most restrictive being a denser cat.
The car sounds amazing IMHO. It really surpasses my expectations in the sound department. The car also feels like it spools a little better, but that could be placibo effect too. Overall not a bad mod and I think it will hold me off from spending any money on a real exhaust setup for a little while
My understanding is you have 2 300 cell cats on each side.
I don't have to worry about emissions and right now I can't afford to pay the $ it takes for a Markski or Switzer exhaust.
I used a 74mm hole saw and actually took out a little more then that out of the 1st cat from the turbo. I wanted to leave some for kind of a baffle effect.
I had already used a 1 7/8" hole saw like you did right after I got the car through the tail pipe.
Here is a sound clip from a cold start. I agree w/ you, I am happy till I can get a real exhaust. Drone is gone by maybe 85+%. and only between 1700 & 2300 rpms.
I took this clip on my Iphone, what do you guys think?
http://www.youtube.com/watch?v=mazzq...e_gdata_player
That might be, I'm no expert. I was told this by an after market exhaust maker.
I did find the cats closest to the turbo to be twice as long as the other. Also, they look to be about the same in density.
I am not sure how much HP gain there is but you would think allowing the car to breath better would help some. The dyno from just opening up the tail pipe was 12HP. It is in the 25+ page tread on the mod.
I hope to get a real after market at some point but I have a lot of other things going on and can't spend that kind of $. Plus now that I have something that sounds better I am thinking I need to work on the suspension.
about time u modded that car man...
mines in pieces when i get the low down ill give ya a call
Hogapalooza,
Initially the cats looked the same to me too, but if you look at the holes in the cat material you can see the secondaries have substantially smaller holes than the primaries. But like I said, I have no clue what the actually cell count is for sure.
VAGscum, you are probably right. In the end it really doesn't matter to me because the exhaust sounds way better then stock.
I'm not sure if I still want an aftermarket exhaust now because it will be
" so " much better or if it is to say I have " X " exhaust.
For me at lease, it's hard to read this place and not want to spend $$ on mods to keep up w/ the pack.
But this mod if very similar to Ruf & PBK and for about 5 1/2 hrs work ( for me at lease ) it was worth saving the 3K for the a real aftermarket exhaust.
Even a good used 1 will cost $1,200+ and that is a new rear GT3 adj. sway and Tarret drops w/ $600+ left over for something else.
Like I said, I am not sure if I won't just spend the mad car $ I save on other mods for now and worry about an exhaust later or not?
Well a good tuner can get you about 80HP for about $1800. ( + or - on each $ & HP )
No 80hp from just a tune. Hey you live in denver. There is a stock k16 car with just a tune and exhaust and you can compare to see how much more power that gives you.
