Cayenne Turbo All Cayenne Turbo model topics
have I made a big mistake blocking a vacuum hose?!?!?
Old Apr 23, 2021 | 01:18 PM
Richard Godsall's Avatar
Richard Godsall is infamous around these parts
2008 CTT
Temp repaired the AOS diaphragm with cling film and it's fixed the a rough running problem that's plagued me since i had the car. Car feels lovely and smooth, really like i've never experienced!! However, the idle has become lumpy. I'm assuming the diaphragm leak 'profile' has now changed (didn't get a perfect seal with the cling film), hence slightly different symptoms.
Can't wait for the replacement diaphragm to get here!
However when I got home to remove the cling film (didn't want it disappearing into the engine), I found that the plastic cover of the camshaft adjuster, just below the AOS, pictured below (before the oil accident), had 'shot' off, and oil had been squirting (at some pressure) up into the underside of the bonnet! Now i'm a bit puzzled...
I was also wondering if this might be related to my blocking up the t-piece with a wood screw and bicycle inner tube dust cap, thereby increasing pressure somewhere???...Perhaps someone could confirm (perhaps have a quick look at your car??) and tell me what this pipe is, and if it should be open to atmosphere, or blocked off....or connected to something else...kinda looks a little incongruous to me..I found some pics online of what I thought was the part that showed a cap...
Oh, and this morning the starter didn't want to turn, and then 3 seconds later (when I assumed I had a flat battery,) it roared into life at the next key turn...suspecting dying starter...
one day I'm sure that (mostly) everything will be fixed!!!
Bit more history can be found from my last few posts here: https://www.6speedonline.com/forums/...istency-2.html
Thanks in advance to anyone that can help!! - Also hopefully someone can solve their rough running to the AOS diapghm...it really was a eureka moment for me
before the leak
Old Jan 23, 2022 | 03:38 PM
SRT88's Avatar
SRT88 is infamous around these parts
I know it is an old thread but it is left without an answer. No you didn't make a mistake! This vacuum T pipe has to blocked exactly as you have done it!
boyg
Jun 16, 2020 10:31 AM
Brainfry
Dec 30, 2019 08:31 PM
Boondar143
Oct 25, 2019 07:46 AM
menchacai
Cayenne 955/957
Apr 3, 2019 06:14 AM
phantasylink
Jan 20, 2018 02:03 PM
