HELP!!! Cayenne S 2004 Stuck in garage OMG!
Old Mar 1, 2013 | 09:30 AM
blueflame_99's Avatar
blueflame_99 is infamous around these parts
Exclamation HELP!!! Cayenne S 2004 Stuck in garage OMG!
Hey guys! I feel so embarassed... I was idling my dad's 2004 Cayenne S in the garage just to keep the battery alive for the winter and totally forgot about it overnight! Needless to say, it ran out of gas, and then it ran out of battery power =O
To make matters worse, the hood of the car is tucked away just 6 inches beneath a large shelf, so I cannot open the hood..... =O
So:
1) I'm out of gas
2) I'm out of battery power
3) I can't open the hood
How do I start this car???
I do have roadside assistance. What should I do? Is there a way to put the car in Neutral from this position? Maybe get it towed a little way out and then boost it? Would any mechanic be able to do it? Please help!!
Old Mar 1, 2013 | 11:47 PM
nuttersandy's Avatar
nuttersandy is infamous around these parts
That's quite the odd situation lol. I can give you some advice, if you have a battery trickle charger, you could plug it in through your ashtray and let that charge for a couple of hours and then turn the ignition on, and roll the car in neutral?
Also, I believe the battery is located under the driver's seat.
Old Mar 2, 2013 | 07:21 PM
01tj's Avatar
01tj is infamous around these parts
How do you do that through the ashtray? My trickle charger has a + and - clamp like jumper cables. In my car I have a place under the hood to connect them
Old Mar 2, 2013 | 08:03 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
there should also be a manually shift lock release for the shifter. indont know where it is in the older cayennes but in the 958s its underneath the ashtrash, u pull it out and theres a spring loaded button/switch u have to push down with a screwdriver and u can shift the gearlever into neutral to push/roll the car. look in the manual and it tells you how to do it.
GCBC's Avatar
GCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond repute
Lol @ situation.
i'm no help
Old Mar 4, 2013 | 03:28 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
The main battery is located under the driver seat, not under the hood.
So the steps would be:
Option A
1) Put atleast 5-7 gallons into the vehicle. Note: Someone said that any less than 5 gallons and the vehicle will not try to start as a safety precaution- to prevent the pumps from running dry again.
2) Open owners manual and figure out how to lift up the driver seat to expose the main battery
3) Put on charger directly on battery.
4) Wait....
5) Start car and bandage your pride
or
Option B
Take the easy (albeit embarrassing) way and call AAA
Old Mar 4, 2013 | 04:27 PM
ebanul's Avatar
ebanul is infamous around these parts
You could always get some "Car Dolly" wheel movers...
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
alwaysbored786
Apr 19, 2016 05:51 AM
raaspaza
Bentley
11
Sep 9, 2015 08:51 AM
I'mAllIn
Aug 25, 2015 09:44 AM
