Cayenne S 2004 buying advice / help
Old Apr 7, 2013 | 02:50 PM
shavkaca's Avatar
shavkaca is infamous around these parts
Hi, I am new to the forum and would like to have an advice from you.
I am in a process of buying a 2004 Cayenne S with 127000 miles on it.
The car seems to be in good overall shape, engine sounds good, transmission shifts well.
One problem is that the car starts heavily, I mean when the key is turned to start the car, it seems as the starter is working hard and the engine is turning heavily. But when the engine starts it works fine, n stalling or anything. RPM's are stable as well. Car drives well with adequate power for this vehicle.
I connected my OBD II scanner and got code P0021. I researched it on forums and got different opinions as what can be potentially wrong with the car.
The owner told me that he has this car for last two years and it has always been starting hard. He replaced battery just recently as well as oil and coils with spark plugs.
My question is, can there be anything serious wrong with this (simple) diagnosis with this car with heavy starting and code P0021?
Also, generally, I know 127K is a lot, but shall I go for the car, owner tld me that everything was changed, as in regards with regular maintenance, including drive shaft, pipes and etc.
Thanks in advance
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
socialpro
Cayenne 958
May 18, 2016 09:58 AM
raaspaza
Bentley
11
Sep 9, 2015 08:51 AM
