Cayenne turbo
Old Jan 23, 2014 | 06:59 AM
rulaifu's Avatar
rulaifu is infamous around these parts
Cayenne turbo
Today when I am driving, it has the warning showing on the screen, which is WARNING CHASSIS SYSTEM
Has anyone has the same experience? What will be the best way to check. What will be the cost to fix it?
Name:	CHASSIC SYSTEM.jpg
Old Jan 28, 2014 | 02:06 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Yes, I have seen it - it is from either your PDCC or air suspension. Given the cold temperature I am seeing on your cluster, it could be nothing at all to worry about; considering that your air compressor may have been just warming up.
First I would warm up the car, turn it off for 5 mins, then turn it back on to see if it goes away. If it does, then I would not worry about it unless it comes back.
Old Jan 28, 2014 | 11:27 AM
digitaljok's Avatar
digitaljok is infamous around these parts
Wow, that's cold! When I got that exact same warning, it ended up being PDCC. Replacing a slowly leaking valve block was covered under CPO, but parts and labor would have been $1000+ USD (dealer prices), by my estimate. Good luck!
Old Feb 15, 2014 | 02:52 PM
sparky2150's Avatar
sparky2150 is infamous around these parts
Has anybody purchased an air suspension compressor repair/rebuild kit from bagpipingandyy in the UK ? The kit includes a new piston ring, bolts. and o-ring. sells for about $30. I have "air suspension faulty workshop" code. I believe compressor is taking to long to pump up at start-up and times out to bring up code.
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
