Cayenne TT very slow after 110mph
Old Nov 7, 2014 | 04:40 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Have you noticed that cayenne become very very slow after 180/h .. At 190-200 it nearly dies . I had some opertunity to push it hard these days and was really hoping to go 150mph+ ... But man its slow
Old Nov 7, 2014 | 11:01 AM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
you're missing a ecu tune....
Old Nov 7, 2014 | 11:56 AM
I have a custom 91 octane ecu tune ? are you suggesting its a bad tune ?
Old Nov 7, 2014 | 05:39 PM
geetee's Avatar
sorry didnt' see your sig...you have more mods/hp than I do
I'm not sure why you get slowed down...i still pull strong at more than that
Old Nov 8, 2014 | 12:36 AM
No problem sir . Still trying to figure out why is it so slow compared to ml63 and x6m . Thinking of upgrating the turbos
Old Nov 8, 2014 | 11:20 AM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
that's strange maybe you have a boost leak of some sort. even my n/a v8 pulls strong until about 120-30 then it feels like it falls flat on its face and creeps really slow to 150mph.
Old Nov 8, 2014 | 01:39 PM
Mr. Haney's Avatar
Mr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to behold
I don't think you should be having that problem.......
Stock,
Old Nov 8, 2014 | 01:43 PM
BG305's Avatar
BG305 is infamous around these parts
I think you need to have that tune checked. I hit 150mph on mine bone stock, well it did have K&N filters at the time.
Old Nov 8, 2014 | 02:31 PM
I was with 2 300lbs friend onboard when I tested it . I have reached 150mph stock , alone with it and fast on a short road And was hoping to be faster with boltons . My tune pulls more than 0.9 bar .. I will try to put 100 octane to it soon.
Also I didnt say it stops at 130mph , but after that it becomes really really slow
Old Nov 8, 2014 | 03:28 PM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
That extra weight is probably what did it. My car is nowhere near as quick when its full of people.
Old Nov 9, 2014 | 08:56 AM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
The truck is a brick aerodynamically. Weight doesn't matter as much for top speed. Aero matters more. It's not surprising the accelerates much more slowly after 100mph.
You guys have brass ***** doing 150mph in a 5500 brick...
Old Nov 9, 2014 | 07:02 PM
shifter_'s Avatar
shifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond reputeshifter_ has a reputation beyond repute
I've had my 958 over 150mph a few times and up to 170mph once and that was before the ECU tune.
remember, there's a lot of wind resistance at the higher speeds.
but it gets to 150 in a hurry. 150 to 170 takes a while and at that speed the wind sounds like a 747.
however, the 957 weighs a ton more and has less power, so I have no idea if any of this is applicable to you.
Old Nov 10, 2014 | 12:59 AM
958 weights around 300lbs less than 957 . Same engine but I have bolt ons . 958 is faster because my final gear is 5th and yours is 7th ?
I think the problem are the camshaft which makes peak power at 4500rpm but when you are running a shift it goes at 5000rpm so we dont have than much power left ?
Old Nov 12, 2014 | 09:21 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
@porschecayenne92
With those bolt-ons, you should be blowing right past 110 mph. Yes, it makes peak power around 4300 rpms and wind-resistance is brutal at 130 mph +, but it still has alot of power up to around 6200 rpms. Then the top end drops a little to redline around 6750 rpms.
All said, depending on the severity, you might have another issue.. When is the last time you replaced your MAF? Have you ever had your fuel pump replaced?
Old Nov 13, 2014 | 12:53 AM
I had an extra 600 lbs on the car . I replaced my fuel pumps 1 year ago ,all three of them. The mafs are located in the plenum pipes wright ? I think the mechanic maybe cleaned it when installing the ipd plenum . Anyway inshallah if everything goes ok I will become a panamera turbo owner !
