2006 Cayenne will not start
Old Nov 19, 2014 | 08:57 PM
Erven Taylor's Avatar
Erven Taylor is infamous around these parts
Hi Guys I need some help trouble shooting my wife's cayenne. About a month ago I replace both fuel pumps and the truck has been running great until yesterday, leaving work the truck would not start, got it towed to the house.
Here is the problem it turns over strong, will not start but when you release the ignition it continues to turn over until you turn it off to take the key out.
any help would be greatly appreciated. I am about to take it to the stealers.
Old Nov 24, 2014 | 12:15 PM
DLF's Avatar
DLF
DLF is infamous around these parts
The only time I experienced something like that was once when I fitted "bosch" MAF sensors (bought on fleabay) which turned out to be fake. Anyway, she would turn over but not start. I also remember that the problem did not start immediately , but only a few days after they were fitted. There were no warning lights or fault codes. I was able to start the car with the MAFs disconnected (with a PCM Failure warning on the dash) . The problem went away as soon as I fitted proper the OEM Porsche MAFs back. So I suggest pulling the plugs off your MAF sensors and check if she starts (there is a default mode that will allow the engine to run without MAF inputs) if it doesn't work, at least you would have eliminated one possibility.
Old Dec 2, 2014 | 09:48 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Sorry, without codes or anyone with the same exact symptoms, it will be hard to say for sure what is going on here.
GrantRR
Jun 28, 2018 03:33 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
