Lowerlink Nay or Yah?
Old Feb 28, 2015 | 02:07 AM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
Ok, I have a set of lowerlink here. I am still debating about install them or not. All I wanted is to have the "unloaded height" look while driving. I am just concern about the ride quality. A nay or a yah? Your opinion is appreciated. Thanks.
Old Feb 28, 2015 | 09:54 AM
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
I would and do have them on my cayenne. Originally I lowered her it bit too much for comfort so had to raise her up a tad bit. It's an easy mod so if you don't like it you can always swap back.
My only concern was trying to figure out how much to lower the front versus the rear to keep with in factory specs.
Old Feb 28, 2015 | 10:39 AM
bansasn's Avatar
Since the stock length is 87mm front and rear. If I do decide to install them. I'm thinking for the front 105mm and rear 104mm. It's about 1 inch difference in length from the stock. Thanks for the comments.
Old Feb 28, 2015 | 10:47 AM
C4SxM5's Avatar
My stock links were not the same from front to rear, so not sure if it's different from turbo vs other cayenne models but that's the only issue I haven't really resolved.
Old Feb 28, 2015 | 04:09 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
to lower, you have to shorten the links iirc...also shortening about 8mm lowers the car about 35mm.....which i find a little too bouncy in sport level
Old Feb 28, 2015 | 04:10 PM
geetee's Avatar
stock link lengths are the same...the direction of the attachments are different between front and rear though
Old Feb 28, 2015 | 04:24 PM
C4SxM5's Avatar
My links go longer makes the car lowered. Shorter makes the car higher...
I'll re measure my oem links when I get my car back but I'm pretty sure the overall length of the links from from to rear are different.
Old Feb 28, 2015 | 08:27 PM
bansasn's Avatar
Well..did it. Installed the lowerlinks. On my original link it measured out 87.5mm front and rear. I added 5mm more to the lowerlinks as instructed on the manual. Total length is 92.5mm.
So basically I lowered an inch. Ride quality on sport mode is a little stiff. Comfort feels good. Standard mode I don't feel that much of difference with sport mode. I think the setup is just right. Any lower you probably can feel every bump on the road.
I might need an alignment. When I took my hands off the steering wheel on the freeway. I notice the car started to subtly steered toward the right. It was an easy modify. If I get tired of the setup I can always put the OEM back.
I didn't have to take the wheels off for the front. But I had to for the rear.
Old Mar 7, 2015 | 12:30 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
every cars different. my audi you make them shorter, the cayenne you make them longer. mb sl's you make the front longer and the rear shorter. they work different for every car and manufacturer.
Old Mar 7, 2015 | 07:00 PM
geetee's Avatar
i have links on mine... for some reason i thought i shorten them
your right, i did lenghten them to lower
Studio RSR
BMW //M
Aug 25, 2015 05:48 PM
Nissan GTR
Aug 19, 2015 02:11 PM
WyattH
Ferrari
11
Mar 21, 2007 02:21 PM
