Move selector to level P
Old Aug 6, 2015 | 10:45 AM
joeadzz's Avatar
joeadzz is infamous around these parts
Hi,
Does anyone get the same message when parking the car for 04 Cayenne S. It is coming with move selector to level P and the key won't release. When I move to the left again like turning off the ignition is when it is making the click noise and releases the key. This happens every now and then. Also could that be the answer for the psm failure workshop when the car is stopped on D it shuts off. Then when I restart the psm failure workshop light comes on and the engine works strange. After I restart the engine everything back to normal. Anyone had similar issue and what it would cost to repair? I called couple of dealerships and am getting different responses, not sure if both are connected with each other. Airflow sensor, crankshaft sensor, ignition switch. The tires are new, the alignment is ok.
Old Aug 11, 2015 | 08:10 AM
walid's Avatar
walid is infamous around these parts
Hello,
I have the same problem and i don't know how to repair,
Old Aug 16, 2015 | 03:12 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Obviously that is not normal behavior. I have heard of a few ignition switches needing to be replaced.
Old Aug 18, 2015 | 10:33 AM
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
check for water under flooring, both sides - driver and passenger.
Old Dec 9, 2015 | 08:21 AM
PupC's Avatar
PupC is infamous around these parts
My CTT has been displaying this message. It was corrected yesterday ... The shift lever cable needed adjustment... The cable that connects to the shifter connects via a elongated slot ...
To adjust, the shifter must be removed and the allen head screw that attaches the cable must be loosened, selector in park , then the cable pulled so that the the screw can be tightened with the cable pulled all the way forward in the slot..... Hard to describe... If it is off even 1/8' the selector doesn't know what gear it is in... In my case I had what appeared to be another detent for drive..
If the adjusment is far enough out of whack, you may have to put vehicle in neutral, (if you can find it), just to start the car. Mine was waaaay off! To the point of putting vehicle in Park wasn't park, it was actually in reverse, and the car would roll back if I left ignition on!
Taking the shifter out is no big job, I can remove/reinstall it in 40 minutes
agter doing it the 1st time... Adjusting the cable is strait forward as long as you understand how it works...
Took me a long time to figure this out and searched MANY threads and forums without luck....
If I can help please let me know...
Pup
Old Feb 24, 2016 | 05:41 AM
walid's Avatar
Hi PUP,
Thanks for your help,
Do you have pictures of this cable,
Thank's
Walid
Pup
Old Feb 27, 2016 | 02:29 PM
Johnnny B's Avatar
Johnnny B is infamous around these parts
My truck also has this problem. Anyone fix it for good?
Wheeler
Sep 22, 2015 08:02 PM
ModBargains
Sep 10, 2015 12:00 PM
Socalsporty
Sep 9, 2015 10:07 AM
