Cayenne turbo intermittent Ac problem
Old May 17, 2016 | 05:50 PM
Pkcayenne's Avatar
5 Year Member
Pkcayenne is infamous around these parts
Hi all I'm having a weird issue with my 04 CTT when I drive to work the fan run blowing air no Ac until 45min into my drive then it suddenly starts working blowing nice and cold leave the car at work return to the car and the Ac works perfectly from turning the key all the way home weird.
Any ideas checled the Ac charge and it's good.
Old May 20, 2016 | 08:39 PM
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
That does seem odd. Does it do it in auto temp mode only? Have you tried it in manual mode where you control the temp and blower speed? If it's only doing it in auto mode I'd have to guess there's a sensor somewhere that is not getting the right temp or something. But I'd have no idea where or what to look at.
Old May 26, 2016 | 12:04 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
AC systems have a low pressure switch in them that when the refrigerant is low it disengages the compressor. I wonder if your low pressure switch is failing or has a loose connection?
Old May 26, 2016 | 08:24 PM
vetkiller's Avatar
vetkiller is infamous around these parts
Crazy, I have the same issue in my wife's Land Rover right now. I am going to try re-charging it this weekend. I hope mines not the compressor. Try charging it first.
REDNOSEGT
Bentley
25
Feb 12, 2024 06:39 AM
Dilagan1
May 20, 2016 09:32 PM
mlife2878
Apr 11, 2016 07:51 PM
Fuzzo
Cayenne 955/957
Mar 30, 2016 08:06 PM
