Hazards turn on when car locks
Old Jun 11, 2019 | 08:55 AM
GeraldCheryl's Avatar
GeraldCheryl is infamous around these parts
Originally Posted by smartrepair
With this problem, when I lock the doors, there´s a fast clicking noise coming from inside right side, rear panel, in trunk. It has nothing to do with hazard relay, which seems to be in front.
You mean to there is no need to do anything with relay but locksmith asked me that the problem's in the relay
Old Jul 8, 2019 | 10:19 AM
EasonApollo's Avatar
EasonApollo is infamous around these parts
I never seen any issue with our car door lock but yeah once i hired long island locksmith to repair the door lock jamb when it's broken.
Old Dec 25, 2019 | 03:48 PM
Skely330's Avatar
Skely330 is infamous around these parts
Hi
did anyone sort this problem, when I lock the doors there is clicking sound, hazard lights keep flashing also rear trunk interior lights stay on
Old Dec 26, 2019 | 11:32 PM
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
read fault memory first.
Old Dec 27, 2019 | 03:39 PM
Skely330's Avatar
will do
Old Dec 15, 2020 | 02:58 PM
CeeeRock's Avatar
CeeeRock is infamous around these parts
Same problem with my 2011 Cayenne.
Originally Posted by Skely330
Hi
Same problem with my cayenne. Unless I hold down the lock button for 5 seconds
Old Mar 13, 2021 | 09:21 AM
LeePanameraTurbo's Avatar
LeePanameraTurbo is infamous around these parts
Hazards continue to flash after locking car unless held for 5 secs
hi
did you you find a solution..? I’ve got the same issue brand new battery, hazards light flash if I press and release fob button doors lock but hazards continue to flash!!! If I keep hold of the lock key on the fob for 5 seconds wing mirrors fold in and hazards don’t flash... confused
any help will be greatly appreciated.
regards
Lee
Old May 10, 2021 | 05:39 PM
Porscheman33's Avatar
Porscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud of
I had this issue on my S class, it was telling me the alarm sound died. It didn't do it always. But it would start flashing the hazards like every 5 locks or something like that. I would have to unlock it and then lock it again to get it to clear.
Old May 14, 2021 | 10:32 AM
jcdo's Avatar
jcdo is infamous around these parts
Originally Posted by LeePanameraTurbo
hi
regards
Lee
Hi, were you able to figure out what the issue was? I just got the same problem after my battery died for some reason. 2 Months old batter, jumped started and battery been working since but blinkers turn on after locking is still an issue. Any insight would be greatly appreciated.
JC
Old May 14, 2021 | 10:49 AM
jcdo's Avatar
Hi, were you able to fix the issue? I am having the same problem and driving me nuts.
Old Mar 9, 2022 | 09:06 AM
adiliyoo's Avatar
adiliyoo is infamous around these parts
Bring back from the dead... Was anyone able to fix this? Started having the same issue on panamera. Swapped the battery but didn't fix the issue.
Hazards blinking, trunk not closing properly and clicking noise from behind the rear right panel somewhere when I start the car
Aby ideas would be greatly appreciated, thanks
Old Mar 9, 2022 | 09:20 AM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
It's the alarm module. Has a NiCad battery in it with a 10 year life - at 11 years it goes bad and those are the exact symptoms. The fix is to replace the alarm module. On a Cayenne it's located in the cowl area, dead center, under the windshield wiper mechanism. Figure 2-3 hours labor. The battery is not replaceable, and the unit is sealed for your protection. No idea on labor for a Panny..
Old Mar 9, 2022 | 12:05 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Post#9 above....the fix on my vehicle involved the simple replacement of
part number: 1K8951605B
Horn for the alarm system. It gets wet and fails if you use pressure washers to detail car.
Old Mar 9, 2022 | 01:18 PM
adiliyoo's Avatar
wow, thank you for such quick responses. will start looking into that. Would that prevent the trunk from closing properly too? It goes down, but stop right before closing, gives some beeps and then has to be pushed down manually. but even then one side doesnt allign ...
ps: it all started happening at the same time because the car was sitting in a garage for about a year, so obviously the battery died. replaced the battery, but hazards as well as trunk not closing all started at the same time so I assume its all related?
Old Mar 9, 2022 | 03:50 PM
G_A's Avatar
G_A
blinking caused by siren 99%, located under front fender and has different shape from cayenne. hatch lock not from this opera.
