Bad Water Pump?
Old Jan 19, 2022 | 08:04 AM
Edward Fitz's Avatar
Edward Fitz is infamous around these parts
Bad Water Pump?
Hello! Hope everyone is well
I have a 2004 Cayenne S non-turbo with around 168K miles. Has anyone seen a failing water pump leak onto the pulley like this? It was replaced, along with the thermostat and starter around the time of Texas Snowmageddon of 2021 as the pulley was making all kinds of noise, no leak though. I have seen pictures of failing water pumps with coolant seen under the pulley and around the seal (along with corrosion) and with a quick google search I wasn't able to find a water pump leaking onto the pulley like this. I haven't had one leak before that I can recall and don't have anything to compare.
As the throttle body and intake tubing sits above the pulley, I don't think there is anything leaking onto the pulley, which leads me to think it is the water pump.
Additional symptoms compliment a failing water pump and include: engine temperature rising while the car is idle and the temperature decreases while moving.
Thoughts anyone?
Thank you
onenrg1
May 11, 2014 08:53 AM
Saint Ari
Mar 21, 2013 03:23 PM
simtiaz
Sep 18, 2012 02:17 AM
kabman0210
May 11, 2008 08:19 PM
