958TT rear suspension dropping overnight
Old May 28, 2023 | 12:32 AM
Gtrust's Avatar
Gtrust is infamous around these parts
I’m trying to trace a leak at the rear. Car drops about 1cm overnight equally at the rear, it will go completely down over a week. I put the car into jacking mode in the hope that I’d see just one side go down but again both fell equally. It seems like too much of a coincidence for both bags to go at the same time. I want to narrow down the issue before it goes to the garage. Any pointers on what it’s likely to be and any way to confirm? Thank you for any help. Car is a 2013 958 TT with 80k on it which I’ve owned from new.
Old Nov 28, 2023 | 07:00 PM
OctaneMatt's Avatar
OctaneMatt is infamous around these parts
Common wisdom is it's the orings and upper strut mounts that lead to this. I have the same issue. I've ordered the parts and hope to install them in the next couple of weeks.
Old Nov 29, 2023 | 12:11 AM
Gtrust's Avatar
Thanks very much. Still have the issue, it hasn’t got worse but I need to sort it. Good news that I potentially don’t have to replace the entire strut. Do you have part numbers for the top mount and o rings?
Old Nov 29, 2023 | 11:39 AM
OctaneMatt's Avatar
Here's one thread: https://rennlist.com/forums/cayenne-958-2011-2018/1221386-2011-cayenne-turbo-3-corners-dropping-and-1-corner-raising-leak-in-air-suspension-2.html
top o-ring p/n N-903-677-01
top mount (p/n 958-343-018-20
Old Nov 29, 2023 | 04:10 PM
Gtrust's Avatar
Thanks very much
Mark C
Bentley
Jun 24, 2021 03:12 PM
Steve Jarvis
Aug 2, 2019 04:12 PM
Ktw
Sep 10, 2016 03:08 PM
mep1811
Cayenne 958
Feb 1, 2016 09:50 PM
Lateral G
American Muscle
17
Sep 15, 2010 08:14 PM
