Clear Side Marker Installation
Old Aug 1, 2003 | 12:36 PM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
I just installed the clear side marker's on my father's Cayenne that I ordered from Gert. It's a lot simpler than I'd heard. First off, his truck has the 20" wheels and I did not need to remove the wheels. Here's a simple "how to:"
1. Turn the steering wheel completely so that one wheel is facing in.
2. Remove the 4 torx screws below the light and 1 torx screw above the light (size 20).
3. Pull back the wheel well lining and hold out with one hand.
4. Remove 1 torx screw holding in the light (size 25).
5. Push in the light from the outside and jiggle it loose. You may break the two clips on the light when removing.
6. Disconnect the lightbulb by twisting and pulling. It will pop out. It is not like a 996 that locks in by turning.
7. Note that the lightbulb will plug into a different spot on the European clear light. It installs in the lens that faces the wheel well whereas it plugs into the side lens in the U.S. I left the clear bulbs in as opposed to putting in the yellow bulbs.
8. Carefully put the light back in making sure the two clips lock into place and the light is centered in the opening on the bumper.
9. Install the number 25 torx screw on the light.
10. Pop in the liner and install the number 20 torx screw.
You're done. The first one took maybe 15 minutes. The second one is a 5 minute job. Good luck!
Old Aug 1, 2003 | 05:08 PM
EM 996 GTS's Avatar
EM 996 GTS is infamous around these parts
Thanks... I need that...
but what is a torx screw? which type of tool(s) do I need to replace the clear side-markers?
Old Aug 1, 2003 | 07:25 PM
GT3Scott's Avatar
GT3Scott is infamous around these partsGT3Scott is infamous around these parts
Thanks ESK. I did the other side before your post and removed both the bottom and top TORX screws from the light which was an utter pain in the a**...or should I say pain in the HAND! The second one I only removed the lower Torx and carefully twisted it out which made removing the top TORX unnecessary... and did the same installing it.
Now I have ONE running board left to install and I'm DONE. Except I need to do an oil change... anyone know if the C uses the same oil filter as the 996?
Old Aug 3, 2003 | 05:45 PM
ESK's Avatar
ESK
Hick from NH
Scott,
I'm really looking forward to your pics of the bumper guard and running boards. My Cayenne is crying for some new accessories! BTW, I put some Sport Technos on my father's Cayenne (same color combo as yours). They look great. Nice clean looking design.
Eric
Old Aug 3, 2003 | 06:21 PM
Loren's Avatar
Loren is infamous around these parts
Oil Filter for the Cayenne
The part number for the Cayenne oil filter is 996 197 225 52 and the sealing ring for the drain plug is 900 123 106 30 -- both the same as all Carrera's
Old Aug 3, 2003 | 06:22 PM
GT3Scott's Avatar
Still havent gotten around to the other running board (closing on a new house tomorrow...)... should this week and will post pics!
Old Aug 5, 2003 | 01:46 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Nice the clear markers must be a nice touch, when I first saw the Cayenne that is what I thought it would need and now they are here.
Old Aug 18, 2003 | 11:27 PM
Windforce's Avatar
Windforce is infamous around these parts
Old Apr 8, 2008 | 08:22 AM
Hsiang613's Avatar
Hsiang613 is infamous around these parts
just finished installing mine!! great post!
Old May 10, 2008 | 10:36 AM
liuxiaoyu's Avatar
liuxiaoyu is infamous around these parts
great information,i just installed on my cayenne today.
Old May 10, 2008 | 11:10 AM
Precision's Avatar
Precision is infamous around these parts
Where are you guys ordering the clear side markers from?
Old May 10, 2008 | 11:21 AM
liuxiaoyu's Avatar
Old May 10, 2008 | 11:25 AM
2008cayenne's Avatar
2008cayenne is infamous around these parts
Great post - I now have no excuse not to do mine....
Old Dec 30, 2008 | 06:00 PM
porscheaudifam's Avatar
porscheaudifam is infamous around these parts
ESK
Great directions!!!
Did it from start to finish in less than 30 minutes - set-up, process, clean-up!!!
THX!
Old Dec 30, 2008 | 06:23 PM
have2modit's Avatar
have2modit is infamous around these parts
Dealer charged me a hour worth of Labor for them
