PC question - speed 3, how much hand pressure?
Old Feb 3, 2008 | 01:11 AM
cellg8's Avatar
cellg8 is infamous around these parts
What's the proper way of using pc when at speed 3? I notice if I put full pressure on it (press on top to make it stay down) at speed 3, it either spins counter-clockwise or doesn't spin at all. If I let go a bit, it'll spin clockwise... So how much pressure am I supposed to put on it?
At speed 6, no matter how much pressure I put on PC, it spins clockwise...so I guess I'm doing it right?
Thanks.
John
Old Feb 3, 2008 | 06:52 AM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
I would typically lay down the product on 3 unless its a liquid wax.
start applying the product at 3 and move up to 5 and work the polish in.
Don't put that' much pressure on the machine that it will bog it down.
Old Feb 3, 2008 | 07:41 AM
Grouse's Avatar
Grouse is infamous around these parts
apply at speed three, Don't worry about it spinning. Then bump it up to 5-6. and polish it out till the polish is nearly clear or clear.
Old Feb 3, 2008 | 07:54 AM
MoeMistry's Avatar
Premium Sponsor
Starting at 2-3 to work the product in and I only go as high as 5. I've tried doing 6 afew times and the heat generated melted my backing plate and the the center of the pad.
Old Feb 3, 2008 | 12:21 PM
cellg8's Avatar
Thanks for all the replies! Yeah, I started at 3 but just wasn't sure if I was doing it right because I noticed sometimes it spins clockwise and sometimes counter-clockwise... I guess my question was 'what is the right way when at speed 3'?.
Thanks.
John
Old Feb 3, 2008 | 12:31 PM
Stealth 993's Avatar
Stealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond repute
Yes, pads don't last long at sp6!
Moe, there is a ventilated PC backing plate, it cuts down on 50% of the heat!
Another tip, if you are ever over sp3, do not lift the pad off the surface, you can throw the pad off the PC.
Old Feb 3, 2008 | 01:04 PM
MoeMistry's Avatar
Premium Sponsor
I usually use the pc to finish up after a rotary. In that aspect, I usually keep at 4. If the pads fling off it's because the backing plate needs to be replaced or the pad's "loop" is no longer catching on the "hook" part of the backing plate.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
Nissan GTR
Aug 19, 2015 02:11 PM
