Safe way to remove wax?
Old Jul 27, 2004 | 09:36 PM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
what's the best way to remove wax? We're gonna Rejex the GT2 and i'd like to have all the wax off first. I have heard normal soap can damage the paint. Is this true or can i just break out the Dawn?
-Steve
Old Jul 27, 2004 | 10:13 PM
Dr. T's Avatar
Dr. T is infamous around these parts
Dawn dishwashing liquid will remove any old wax.
Old Jul 27, 2004 | 10:21 PM
FAT-911's Avatar
FAT-911 is infamous around these parts
If you want to do it right check these guys out www.swissol.com
I have a Polar Silver TT and it comes out awesome with this stuff, it is expensive but hey, so is your car, only the best for the best.
Old Jul 28, 2004 | 12:58 AM
NJPete996TT's Avatar
NJPete996TT is infamous around these parts
I would typically go with Dawn as well, but if you are in the mood for something new i believe the NXT car wash has some wax striping capabilities. Check out autopia.
Old Jul 28, 2004 | 01:34 AM
Greyghost's Avatar
Greyghost is infamous around these parts
Dawn and a clay bar.
Old Jul 28, 2004 | 01:37 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
Just use Dawn. I would not want it for regular use, but it is perfect for stripping wax. A clay bar will work too. In fact, do both for best results.
Old Jul 28, 2004 | 12:24 PM
TCM's Avatar
TCM
TCM is infamous around these parts
Dawn, clay, and a precleanser are your best bets. Most sealants come with a cleaning solution to use before applying, I am assuming this is not that case with ReJex. Hope this helps.
Old Jul 29, 2004 | 07:38 AM
HotRodGuy's Avatar
nope, car washes were designed to the wax stays on. A good claying should strip the wax. Most pro detailers try to steer you away from using dawn but once in awhile should be ok.
Old Aug 11, 2004 | 05:06 AM
ChrisNJ's Avatar
ChrisNJ is infamous around these parts
I usually use dawn first (remove wax), then clay (remove any excess wax and contaminants), then wash again w/ mothers/meguiars, then s100 sepc, and finish it off by waxing w/ nxt (can top it off w/ s100 the next day for a little added carnuba touch )
Old Aug 18, 2004 | 11:00 AM
NickShades25's Avatar
NickShades25 is infamous around these parts
Prepsol works great too!
Nick
carbonjim996TT
Sep 20, 2015 08:14 AM
as4driver
Sep 10, 2015 09:32 AM
JSF721
Detailing
Sep 8, 2015 07:57 AM
