Seat stitching
Old Oct 27, 2008 | 09:43 AM
bbywu's Avatar
Seat stitching
I tried searching for seat stitch, thread, and couldn't find a satisfactory answer.
My 997TT's sport adaptive seats have standard stitching...close to the driver side left lumbar support, where the driver enters and exits, the stitching is ever so slightly starting to fray.
Any ideas how to prevent this from worsening? Maybe waxing the threads?
Old Oct 27, 2008 | 10:40 AM
MoeMistry's Avatar
Premium Sponsor
You're just going to have to be aware of not rubbing against the stitching when getting in and out. Not sure if there's anything out there that's going to strengthen the stitching.
Old Oct 30, 2008 | 09:56 PM
bbywu's Avatar
Just an FYI, I ended up using my Panasonic electric razor and gently shaved the micro fibers from the stitch line.
Moe, I guess since there aren't any other tricks to keep it form happening, I'll just have to be extra careful when I exit and enter my car.
Thanks.
Old Oct 31, 2008 | 12:46 AM
MoeMistry's Avatar
Premium Sponsor
Thanks.
Wish I had a better solution for you.
Old Oct 31, 2008 | 09:33 AM
ScheerSpeed's Avatar
ScheerSpeed is infamous around these parts
yea, like moe said, there probably isn't anything out there to strengthen the stiching. at least to my knowledge i have never heard of anything.
Old Oct 31, 2008 | 03:03 PM
Grouse's Avatar
Grouse is infamous around these parts
Fray Check, You can use it to keep the stitching from fraying. That being said, getting it properly on the stitching is a PIA. also be sure to test for color fast and discoloration in a unseen area before application to the whole seat/car.
Old Oct 31, 2008 | 04:40 PM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
This is just a guess, but putting leather conditioner on the seat might soften the leather reducing the tension on the stitching.
John
Old Oct 31, 2008 | 07:00 PM
Grouse's Avatar
John
I think his issue is abrasion of where his body contacts exposed stitching. In that case a product like fray check will help.
If it is a fraying over the entire seat, the I would wonder if he has used any types of cleaners with oxidizers in them. They will often damage cotton/cotton blend threads. causing them to prematurely fray.
Old Nov 1, 2008 | 09:28 PM
bbywu's Avatar
You are correct...I recently changed seating positions, and on exiting, probably have been rubbing up against the side lumbar more often.
Is Fray Check the same stuff that they sell at fabric stores?
Old Nov 1, 2008 | 10:09 PM
Grouse's Avatar
Yes it is, I used it with a bit when cleaning upholstery that had issues with fraying on the beading/stitching. Be sure to test in inconspicuous area, you do not need a lot of it, simply enough to ward off fraying.
Old Nov 1, 2008 | 11:01 PM
bbywu's Avatar
Just an update...I found something called Fray Block, which comes in a tube with a small nozzle...I used a bit with a toothpick, after shaving the fray a little, and it looks pretty good with no discoloration.
Old Nov 1, 2008 | 11:12 PM
Grouse's Avatar
sounds like fray check type product then. Glad it helped keep us updated, I am sure you are not the only guy with this issue.
Rguy
Apr 12, 2020 11:11 PM
jaehoppa
Oct 22, 2015 09:17 PM
HIGHcard
Sep 24, 2015 08:09 PM
FUTURESTAR
Sep 23, 2015 05:42 PM
