Amateur - New To Machine Waxing
Old Apr 22, 2009 | 07:22 AM
  #31
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
Originally Posted by fastsvo
I am little confused here. Which polisher is considered "safer" and the other "better"?
both the flex xc3401 and the PC 7424 are "safe"
however the flex is what most have been going to because it is more powerful and smoother than the PC
Old Apr 22, 2009 | 07:23 AM
  #32
MoeMistry's Avatar
Premium Sponsor
Originally Posted by blitzo
flex is meant to be safer but more expensive. i believe the other is the porter cable which is used by a lot of professionals but trickier to use.
The PC isn't used all that much once someone gets a hold of the flex. The two are completely different animals. FLEX is quieter, has less vibrations, more torque, better correcting ability, a true random orbital polisher, and is built very well. An excellent investment for the pro and DIYer.
Old Apr 22, 2009 | 07:26 AM
  #33
MoeMistry's Avatar
Premium Sponsor
The FLEX is SAFE and BETTER compared to the PC and high speed. Leave the high speed rotary to the professional. FLEX can be considered a hybrid between the older PC and the rotary. It corrects imperfections almost, sometimes as good, as a rotary but it's safe as a PC. This mean you won't burn paint, create further swirls, or buffer trails, Just make sure you use the correct pad/polish combo.
Here's a very competitive special we're running right now on the FLEX:
https://www.6speedonline.com/forums/...y-special.html
Old Apr 22, 2009 | 09:23 AM
  #34
D!Tailed's Avatar
D!Tailed is infamous around these parts
I don't know that this is the case. I use the PC and it's incredibly easy to use. It's the rotary that's trickier (until you "get it")
I would think that the Flex is a bit "trickier" because it has more torque, but then again, it has more torque, so it will be able to correct more quickly.
D!
Old Apr 22, 2009 | 09:25 AM
  #35
MoeMistry's Avatar
Premium Sponsor
D!
The flex is a bit trickier to use in the beginning, but it has a small learning curve. As you mentioned, the greater torque allows for better correction.
Old Apr 23, 2009 | 03:43 PM
  #36
Gungriffin's Avatar
Gungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant future
The first car that I did with the Flex was quite time consuming, but now it is a breeze.
Old Apr 23, 2009 | 03:45 PM
  #37
stevenross's Avatar
stevenross is infamous around these parts
i was very nervous using it the first time.. but now i love it..
Steven
Old Apr 23, 2009 | 04:05 PM
  #38
fastsvo's Avatar
fastsvo is infamous around these parts
Does the flex have attachments available for carpet cleaning as well?
-Eric
Old Apr 23, 2009 | 05:14 PM
  #39
MoeMistry's Avatar
Premium Sponsor
-Eric
Not sure. It is a hook-n-loop system though.
Old Apr 23, 2009 | 06:31 PM
  #40
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
-Eric
any body knows where can I find that carpet cleaner pad
Old Apr 23, 2009 | 06:45 PM
  #41
I don't believe the flex has attachments.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
JWrightPNH
Sep 17, 2015 01:42 PM
JSF721
Detailing
Sep 8, 2015 07:57 AM
AuZZie
Sep 2, 2015 04:26 PM
