Water Deionziation
Old Apr 6, 2009 | 11:30 AM
RDKJ's Avatar
RDKJ is infamous around these parts
Water Deionziation
I am building a new garage with an indoor wash bay and I would like to install a permanent water deionization filter - what brand would you recommend?
Also, if I have a permanently mounted high pressure wand, would you suggest that I have a bypass switch wired to the deionization filter? That would enable me to only use the filter for post-wash rinsing.
Old Apr 6, 2009 | 07:55 PM
MoeMistry's Avatar
Premium Sponsor
The only compact system on the market that actually works is the cr spotless. They have a high output system DIW-20 that would be perfect for your application.
Old Apr 7, 2009 | 08:36 AM
ZaneO's Avatar
ZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant futureZaneO has a brilliant future
I would imagine the inital cost of a commercial-style setup would be significantly more up front but could be cheaper and more efficient in the long run compared to the small capacity of a CR system and limited span of those cartridges. However, I'm not sure of the exact costs and maintenance of the larger setups.
Old Apr 7, 2009 | 09:09 AM
D!Tailed's Avatar
D!Tailed is infamous around these parts
I agree! The CRSpotless is a fantastic system. I have a client who just had one put in his new garage (he named it his D!Tailing garage) and he loves it! Especially with his Black M6!
D!
Old Apr 7, 2009 | 04:46 PM
MoeMistry's Avatar
Premium Sponsor
For a typical DIYer, the resin in the cr lasts about 4-6 months. At $65 a refill, it's quite economical. Here's a breakdown of TDS and output:
Input TDS Level Expected Yield (# of Gallons)
50 ppm............. 1600 gallons
100 ppm............. 800 gallons
200 ppm............. 400 gallons
400 ppm............. 200 gallons
Old Apr 7, 2009 | 05:51 PM
ZaneO's Avatar
Just too many potential factors to give one answer.
I have the smaller CR unit, have relatively hard water, and like to use it for the entire wash. With that combination of factors, the CR does not last very long and isn't overly cost effective.
On the other hand, I previously had access to a 300 gallon tank we filled with RO water for $25 (delivered), but it requires space for tank, pressure washer, etc. If I had space, this is definitely the setup I would have again (or one very similar).
Just my experience
Old Apr 7, 2009 | 07:35 PM
bbywu's Avatar
I use a high pressure washer wand with my DI...it actually uses less water to wash the same amount, saving you DI resin in the long run.
Old Apr 7, 2009 | 10:03 PM
MoeMistry's Avatar
Premium Sponsor
excellent point...a typical pressure washer has an output of 1.5 gpm, and the high-output cr has an output of 4.5 gpm. By hooking the cr to a pressure washer, you now limit the unit's output to 1.5 gpm, almost tripling the life of the resin. A good pressure washer from lowes or home depot should run you $150 and is quite sufficient for the DIYer.
Old Apr 7, 2009 | 11:59 PM
OC Pcar's Avatar
OC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant future
I have a CRSpotless and love it, the only way to wash the car..
Old Apr 8, 2009 | 07:42 PM
RDKJ's Avatar
After a quick google search, I found this item:
http://www.portablewaterdi.com/deionizers.php
Do you see any problems using "Mixed Bed Deionizer Business Model" unit for rinsing?
Thanks,
Rick
Old Apr 8, 2009 | 09:16 PM
MoeMistry's Avatar
Premium Sponsor
Thanks,
Rick
Yes.. that unit will work. Same concept as the cr. The cr high-output system has .33 cubic feet of resin and the unit you're considering has .25 cubic feet. But at $299, it's not a bad deal. I think the cr looks better though and is a much cleaner setup. I don't think this unit comes with a built-in tds meter, the cr does.
I don't think you can go wrong either way. If you'd like the cr unit, i'll take 10% off for you and give you free shipping as well
Old Apr 16, 2009 | 08:40 AM
MoeMistry's Avatar
Premium Sponsor
Thanks,
Rick
Did you ever get the portable di system?
Bmw M3 Guy
Feb 21, 2018 09:29 AM
kristoffer
Cayenne
Dec 20, 2015 03:02 PM
cerbomark
Sep 22, 2015 03:32 PM
