CR Spotless Water Deionization Special
Old Apr 10, 2009 | 08:32 AM
MoeMistry's Avatar
Premium Sponsor
I've been getting more than usual calls and PMs about the Costco deal on the CR Spotless. So here's the deal to earn your business and not lose out to Costco. For a limited time, we're MATCHING the Costco deal less the hose and quick connects.
Here it is:
OFFER ENDS April 17th
Retail DIC-20 and one Resin Refill: $449.99 + $90.00....$539.99
No Minimum Order: $369.99 S+H included (Save 31%) click to order
Product Description:
Hard water spots can destroy your vehicle's finish. That's why CR Spotless Water Systems created a de-ionizing system that takes out all of the minerals in your water so you can just WASH, RINSE, and WALK AWAY! That's right! With a DIC-20 Spotless Water System, you can let your car, RV, house windows, etc., air dry with no worries that hard water spots will appear. Say goodbye to towel drying and the scratches that towels and chamois can cause. You can even give your car a quick 5 minute rinse between washes to keep it looking great all the time.
Besides cars, de-ionized water is perfect for washing and SPOT-FREE rinsing of your:
  • Cars/trucks
  • RVs
  • Motorcycles
  • Boats
  • Golf Cars
  • House Windows
  • Patio Furniture
  • Decks
Customer Testimonials:
Absolutely works. Can't live without it now. Also, get the Airmax dryer from Moe at Glistening Perfection. This two system process will eliminate drying, which will also cut down on the swirling potential from the hand drying. Highly recommended.
chardonet (6speedonline)
Grab a CR system from Moe - you won't be disappointed!
MidnighTT (6speedonline)
If you don't already have the CR system...you definitely need it...fantastic!!! I love mine!!!
TUUNER (6speedonline)
I also purchased a CRspotless, and some other products, from Moe some months ago. I got the same VIP treatment that you experienced. He's a pleasure to deal with. It's great to be able to speak with someone so knowledgeable and experienced. As far as the CRspotless, I concur, it works just as advertised. It's a great time and swirl mark saver.
Paladin (Rennlist)
I received the cr spotless from Moe on saturday. Used for the first time this afternoon. In a word...incredible.Even the windows are cleaner and require no wiping off after wash. Worth every penny. Moe was a pleasure to work with....had a delivery problem and Moe offered a free refill for my inconvenience. Even my wheels are shinier. I was doubtful at first but a friend if mine kept raving about it so I decided to try it. Im glad I did.
points (Rennlist)
Got mine today. Came home from C&C and it was sitting on my doorstep. Washed both cars in less time than I ususally spend on my 997 alone.
Well worth it!! Thanks Moe.
LeNoah (6speedonline)
Got mine last week and fired it up today in conjunction with a pressure washer for initial rinse and semi-final rinse and worked incredible. Just used an open hose for the last few seconds to "flood" and basically didn't really have to wipe anything down... Thanks again Moe
INSman (6speedonline)
Package Contents:
  • DIC-20 with in-line TDS Meter
  • (2) 20" Cartridges Filled with De-Ionizing Resin
  • R2-20 One complete refill for DIC-20/DIW-20
  • 4' Inlet Hose (Attaches to Hose Bib)
  • Nozzle (7 Pattern Garden Sprayer)
  • Roll of Teflon Plumber's Tape
  • Housing Wrench
  • Quick Start Guide/Warranty Card
Features:
  • A water de-ionization system, not a water softener
  • Removes ALL minerals and dissolved solids from the water
  • Battery operated, in-line TDS meter to monitor the water quality in and out of the system
  • Ergonomically designed cart with a padded handle
  • Easy to refill resin or replace cartridges when needed
  • Seven pattern garden hose nozzle with FLAT setting
  • 4' inlet hose to attach to hose spigot
Benefits:
  • Produces 100% pure, mineral-free de-ionized water
  • Pure water evaporates without leaving any spots behind
  • Know when it's time to change or refill the cartridges before spots appear
  • Take it anywhere; easily rolls and maneuvers with one hand
  • No need to send it back for regeneration
  • Flat spray pattern restricts water flow and increases pressure
  • Everything is supplied even the car shampoo and mitts!
System Requirements:
  • Standard Garden Hose Bib
  • Need to Restrict Water Flow to 4 Gallons Per Minute or Less with Supplied Nozzle on FLAT Pattern or Optional Pressure Washer
Expected Yield:
Input TDS Level Expected Yield (# of Gallons)
50 ppm............. 1600 gallons
100 ppm............. 800 gallons
200 ppm............. 400 gallons
400 ppm............. 200 gallons
click to order
Please PM or call 949-355-4911 if you have any questions.
Old Apr 11, 2009 | 12:18 AM
blitzo's Avatar
blitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to behold
what do you mean by "less the hose and quick connects"?
sounds like an awesome deal for all 6speeders. definitely want to get one once i sort out my damn car lol. :-)
Old Apr 11, 2009 | 12:54 AM
blitzo's Avatar
also you mentioned in another thread, about using a pressure wand or pressure washer to increase the usage. Do you also sell a pressure wand on your website?
Old Apr 11, 2009 | 08:50 AM
MoeMistry's Avatar
Premium Sponsor
Costco's deal comes with some quick connects, about a $2 value, and a hose, about a $10 value. Our promo just focuses on the actual system and resin as many people already have a garden hose.
You should jump on this deal.....
Old Apr 11, 2009 | 08:51 AM
MoeMistry's Avatar
Premium Sponsor
No..no pressure washer from us right now. You can pick one up from lowe's or home depot for about $150...it's great for DIYers and triples the life of the resin.
Old Apr 12, 2009 | 11:14 PM
Imaj's Avatar
Imaj is infamous around these parts
Hi Moe...What kind of pressure washer PSI am I looking for? Thanks!
Old Apr 13, 2009 | 02:03 AM
blitzo's Avatar
do pressure washers have an option for soap foam spraying? i read in some other thread about spraying out soap foam. heh maybe i am wrong lol. thnx
Old Apr 13, 2009 | 07:14 AM
MoeMistry's Avatar
Premium Sponsor
Anything around 1800 psi is more than adequate for washing a car.
Old Apr 13, 2009 | 07:15 AM
MoeMistry's Avatar
Premium Sponsor
Models vary by manufacturer. But yes...most do have a reservoir for soap.
Old Apr 13, 2009 | 08:56 AM
D!Tailed's Avatar
D!Tailed is infamous around these parts
First of all, let me say that this is an awesome deal for Moe to do for you guys. I carry the CR spotless as well and I can tell you that by doing this, he's taking care of you guys to earn your business because the margins are VERY slim. Kudos to Moe!
On the Soap in the pressure washer question, some do contain reservoirs for soap, but they really aren't all that great. What works best is to get a foam lance that will really put a thick coating of soap onto the vehicle and help lift the dirt particles to the surface.
Check out the difference between a cheap Karcher Foam lance and a good quality foam lance (For reference, the Karcher foam lance results are very similar to what I get with the onboard car wash reservoir on my Karcher Pressure Washer:
(borrowed these pics, but you get the idea)
And then with the foam lance
Sorry to go off topic a bit, just wanted to add my 2 cents on the pressure washer question.
Thanks again to Moe for this great CR Spotless deal!!
Jump on it guys!!
D!
Old Apr 13, 2009 | 09:11 AM
mburns813's Avatar
mburns813 is infamous around these partsmburns813 is infamous around these parts
Great deal Moe. I think I'm going to try and pick one up if I can convince my friend to pay some for one lol.
Old Apr 13, 2009 | 09:12 AM
MoeMistry's Avatar
Premium Sponsor
You'll wonder how you detailed without it Matt. Hook it up to a pressure washer and you can use it for months depending on how many cars you're detailing.
Old Apr 13, 2009 | 09:14 AM
mburns813's Avatar
Great. I've really wanted one so I'll also have to try and sell it to my parents lol. I'm sure I can get them on cleaning the windows of the house etc.
MoeMistry's Avatar
Premium Sponsor
Jump on it guys!!
D!
WOW...big difference. Thanks for sharing.
This is an AMAZING deal. I got tired of reading all the threads about how cheap costco was selling these units only to read more about how people missed the one or two units on the shelf.
We can sell these units at this special for as long as this promo is going....so BUY BUY BUY
Old Apr 13, 2009 | 09:16 AM
MoeMistry's Avatar
Premium Sponsor
I almost forgot...you can use it obviously anywhere you don't want water spots. Boats, windows, patio furniture, motorcycles, etc.
