how to keep tire spray on tires & off paint???
Old Apr 28, 2009 | 08:47 PM
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
probably a really stupid question but I can't stand how tire shine spray gets all over the car right after i wash it, so whats your technique?
i basically have tried the spray white foam kind and let the car sit in the sun for a few hours or the car in the garage over night, but as soon as I hit the road there are specks all over the doors and rear panels.
also tried the gel kind and the same thing happens. even went as far as spraying the tires, wiping the spray off the tires, and same thing happens so any suggestions would be greatly appreciated
Old Apr 28, 2009 | 09:58 PM
JoshVette's Avatar
JoshVette is infamous around these parts
A couple things to say off the top of my head....
First off, throw out the gels, silicone and spray on dressings. They will only build up and sling off or the over spray will get all over the car.
Secondly, find a good water based dressing, look for a milky like product, not clear or gel.
Third, apply it to an applicator and lightly rub it on the tires.
Lastly, after you're finished with all 4 tires, go back over each tire with the applicator and no dressing and wipe it dry or wipe off any excess build up that there may be. Usually I do not get much build up but maybe just a little so I rewipe it all.
Once it's dried it should not sling.
Josh
Old Apr 28, 2009 | 09:59 PM
AP2FTW's Avatar
AP2FTW is a splendid one to beholdAP2FTW is a splendid one to beholdAP2FTW is a splendid one to beholdAP2FTW is a splendid one to beholdAP2FTW is a splendid one to beholdAP2FTW is a splendid one to beholdAP2FTW is a splendid one to behold
that's the ticket
Old Apr 29, 2009 | 06:00 AM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
I would have to agree with that process that's what we do.
A few dressings to look at
Einszett Rubber/Vinyl Care
Swissvax Pneu
Applicators that work well
Uber small blue
Uber large blue
Old Apr 29, 2009 | 07:28 AM
MoeMistry's Avatar
Premium Sponsor
Originally Posted by joshvette
a couple things to say off the top of my head....
Lastly, after you're finished with all 4 tires, go back over each tire with the applicator and no dressing and wipe it dry or wipe off any excess build up that there may be. Usually i do not get much build up but maybe just a little so i rewipe it all.
Josh
+1...
Old Apr 29, 2009 | 07:34 AM
Detailed Image's Avatar
Detailed Image is infamous around these partsDetailed Image is infamous around these parts
One thing that I find that helps prevent sling as well as increase the durability of your tire dressing is to properly prep your tires before applying the dressing. Use a degreaser on your rubber, such as Poorboy's Biodegradable APC or P21S Total Auto Wash, along with a firm brush and scrub your tires prior to applying your dressing. This will help remove embedded contamination and allow the dressing to properly penetrate your rubber, rather than sit on the surface which can provide additional sling.
As others mentioned, invest in a water based dressing that will absorb into your tires and nourish the rubber. I enjoy using Poorboy's World Bold 'n Bright.
Hope this helps.
George
Old Apr 29, 2009 | 09:29 AM
C4SxM5's Avatar
thanks for the tips guys, i knew i was doing something wrong
Old Apr 29, 2009 | 11:45 AM
D!Tailed's Avatar
D!Tailed is infamous around these parts
Hope this helps.
George
I completely agree.
Most people just keep putting more and more dressing on tires. You need to get the old stuff off first. So get a good tire cleaner as George mentioned above and a nice stiff bristled brush and clean your tires first. Rinse them well, let that dry, or dry them and then apply your dressing. I'm really fond of Meguiars Detailer Line Hyper Dressing. It comes in a big bottle (gallon?) and you dilute it with water in a spray bottle to your desired shine. I apply it with a Tire King applicator, let it sit and then go over it later with another light coat if I feel it needs it. And I don't have any problem with sling. I also know that the Zaino tire stuff is pretty good as well. But almost anything in an aerosol can that you spray on and it foams up will sling (at least the stuff that I have used)
But you've got some great advice from all of those who have posted already!
D!
Old Apr 29, 2009 | 12:47 PM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
I learned about spray tire foam / tire dressings the hard way. There is just no way to stop the spray from floating around. I'm not a pro detailer, but I use the Surf City Garage Beyond Black tire dressing; applied with a sponge tool. Great stuff. Before application though, I clean the tires with Griot's Garage rubber cleaner, then rub them down with Griot's Rubber Prep. THEN the surf city stuff goes on. Lasts a long time that way. Great thread.
Old Apr 29, 2009 | 12:53 PM
D!Tailed's Avatar
I would also add that with the spray stuff, if you are spraying directly on the tires then chances are you are getting that stuff on your paint as it tends to float in the air a lot. This is the reason why I will do my fender wells and my first run on the tires generally before I get into the polishing or LSP application.
D!
Old Apr 29, 2009 | 02:02 PM
Rezmoto's Avatar
Rezmoto is infamous around these parts
great post!
Old May 13, 2009 | 06:36 PM
C4SxM5's Avatar
do local shops carry any of these tire dressing? went to kragen and they pointed me to the spray stuff again...
Old May 13, 2009 | 07:05 PM
D!Tailed's Avatar
The Meguiar's detailer line stuff you can find at some of the paint and body shops. Meg's has a locator on their site so you can plug in your info and see who carries it close by.
D!
Old May 18, 2009 | 06:43 PM
slanguage's Avatar
slanguage is infamous around these parts
einmann fabrik tire cleaner is supposed to be an excellent tire cleaner. I have used Chemical Guys grime reaper and 1Z blitz before with good results.
Some nice tire dressings would be tropi-care tire dressing or 1Z rubber care.
I apply mine by spraying on the tire, wiping with a foam app, anf then wait about 15 minutes. Then I go back and buff off any excess with a dedicated MF towel.
Old May 18, 2009 | 06:46 PM
Tito's Avatar
Tito has much to be proud ofTito has much to be proud ofTito has much to be proud ofTito has much to be proud ofTito has much to be proud ofTito has much to be proud ofTito has much to be proud ofTito has much to be proud ofTito has much to be proud ofTito has much to be proud of
Anyone care to educate me regarding the " First off, throw out the gels, silicone and" Part
