Cleaning Wheels / Cleaning Rotor Rust
Old Jun 26, 2009 | 11:03 PM
996TTDave's Avatar
996TTDave has a spectacular aura about996TTDave has a spectacular aura about996TTDave has a spectacular aura about
I'm having a bit of problem when cleaning my car, hoping for some advice... Car is a Ferrari 360 Modena
Before washing my car i clean my wheels - This includes cleaning the outside and inside of the wheels behind the face and whatnot - after spraying them down with water, the rotors develop a glaze of rust on their surface which is gone after a short drive and applying the brakes - The pads simply clear the rust off - I assume this is true with most cars considering the rotors are cast iron
Anyway, after an initial drive that rust sprays itself all over the interior of the wheel and the once clean wheel must be cleaned again, using a rag and some cleaner or water itself - But i have to clean the wheels twice and it takes up a considerable amount of time
Is there any kind of solution for this problem besides going carbon ceramic or purchasing any kind of new rotors/pads/brakes? Thanks
Old Jun 27, 2009 | 02:31 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
[Is there any kind of solution for this problem besides going carbon ceramic or purchasing any kind of new rotors/pads/brakes? Thanks ]
Metal + Water = Rust
Without replacing the rotors with Zinc coated or Ceramic, there is nothing I'm aware of
i
Old Jun 27, 2009 | 08:50 AM
MoeMistry's Avatar
Premium Sponsor
The orange rust you're seeing is from a couple of areas.
1. There will always be a small film of semi-metallic particles on the rotors because of your brake pads. This will turn the rotors an orange color on the surface but goes away as soon as you drive and use the brakes.
2. Within the rotors, there are channels inside the rotors that get brake dust inside them. If you don't get all the dust out of those channels, water builds up, turns the dust into rust, and as soon as you drive, the centrifugal force splashes the rusty water inside your wheels.
To remedy the situation, make sure to flush out the brake dust inside the rotors and behind the calipers. I basically flush out the rotors and calipers until I don't see any black coming out of the water. When the water being sprayed on the rotors and calipers becomes clear, you've gotten most of the brake dust out.
You may also want to consider a forced air blower system, like an Airmax, that will blow dry the wheels and rotors prior to you driving. This helps because by the time you started to drive the car, the wheels, rotors, and calipers are dry. The airmax comes in handy for quickly drying the rest of the car as well.
Hope this helps.
Old Jun 28, 2009 | 01:27 AM
996TTDave's Avatar
Thanks, i may look into zinc coated rotors!
Hope this helps.
Thanks much Moe - Lotta great tips here, i'll definitely put those into practice next wash - As a last resort i'll have to possibly invest in new rotors
Old Jun 28, 2009 | 01:30 AM
996TTDave's Avatar
Moe - The Airmax seems like a really great tool - Does it really work as well as advertised and described - I'm very interested in it after reading what it does - Thanks again
Old Jun 28, 2009 | 02:39 AM
MoeMistry's Avatar
Premium Sponsor
You'll love it...100% money back guarantee if you don't. Make sure to get the orthotote shoulder strap system...can't do without it.
Old Jun 29, 2009 | 09:34 PM
rgagliano's Avatar
rgagliano is infamous around these parts
Moe, what is an Airmax? If it is a blower, I could use one. Where could I get one? Thanks in advance.
Old Jun 30, 2009 | 05:06 AM
MoeMistry's Avatar
Premium Sponsor
The Airmax is an amazing blower. It has 266 CFM of air velocity, has a dual-stage filter that keeps the dirt and debris from getting into the blower, and it raises the ambient air temp coming out of the blower by 40 degrees to heat the air and dry your car faster.
Here's how to order:
http://www.glisteningperfectionstore...-2200AM/Detail
Make sure to get the orthopedic shoulder pad system to make the airmax more comfortable and mobile:
http://www.glisteningperfectionstore...OTOTKIT/Detail
Old Jul 1, 2009 | 12:08 PM
chardonet's Avatar
chardonet is infamous around these partschardonet is infamous around these parts
Here is a testimonial for the Airmax that I purchased from Moe: I will never wash a car without using the Airmax. I don't MF towel dry any of my cars. I consider the Airmax an essential tool for car upkeep. 'Nuf said...
The_Ruski_Driver
Oct 25, 2015 08:40 PM
roncooper
Aug 19, 2015 01:17 PM
