Detailer's Domain: S2000 CR Paint Correction
The Honda S2000 CR is quite a vehicle. My customer found a brand spanking new one on a lot as these were brought out for 1 year, 2008. It needed some work getting all the swirls out. This car turned out great!
Take a look at the specs from Honda USA:
Premier Performance
Nothing exemplifies Honda racing skill and ingenuity like the S2000 CR “Club Racer.” A firmer suspension, quicker steering ratio and fully functional front and rear spoilers have been specially designed to connect driver, vehicle and road.
Compete
The CR is a true competitor. Feel free to maximize its potential at club racing events.
Performance
A purist’s dream, the factory-tuned CR sports an aerodynamic design and stiffer suspension settings for increased rigidity and downforce. The CR proudly draws upon the S2000’s racing heritage, but delivers more in terms of sheer performance.
Lighter
With racecar-like suspension and lower weight, the CR’s performance is second to none. Drivers rave about its cornering, braking and acceleration. To accomplish this, the audio system and air conditioning are offered as options and the spare tire has been replaced with a tire-repair kit. This, along with other modifications, lightens the racy roadster by nearly 100 pounds from the original S2000. Add in a taut new chassis, quicker steering ratio, “stickier” tires, and track-inspired has never felt so meaningful.
EXCLUSIVE STANDARD FEATURES:
* Firmer springs and dampers
* Stiffer front and rear stabilization bars
* Quicker steering ratio
* Larger rear P255/40 R17 tires
* Bridgestone Potenza RE070 tires
* All-new 17" dark gray 5-spoke alloy wheels
* Fully functional aerodynamic front and rear spoilers
* Yellow and black fabric
* Yellow-stitched seats, shift boot and steering wheel
* Spherical aluminum shift ****
* Removable aluminum hardtop
* Body-colored roll-bar cowlings
* Sport-tuned exhaust silencer
PERFORMANCE FEATURES:
* Skidpad pulls .95G
* Slalom speed 71mph
* Coefficient of lift reduced approximately 70% over original S2000
* Over 2-seconds per lap faster around Japan’s Tsukuba Raceway than the original S2000
Products Used:
Exterior:
Adam's All Purpose Cleaner in the Cam Spray Foam Canon
Swissvax Paint Rubber and Optimum Instant Detail Spray and Gloss Enhancer for clay lube
Menzerna Super Intensive with the Uber Green Pad
Menzerna PO85RD with the Uber Blue Pad
Menzerna Top Inspection
Swissvax Finesse
Einszett Spray Wax
Wheels/Tires/Etc
Einszett Plastic Deep Cleaner
Einszett Wheel Cleaner
Adam's VRT
Uber Boar's Hair Wheel Brush
Swissvax Wheel Brush
Swissvax Autobahn
Adam's Undercarriage Spray
Adam's Glass Cleaner
Tools:
Fenix TK11
Brinkmann MaxFire
Metabo PE12-175
Flex 3403
The Uber Foam Pads (5.5inch)
Tons of "Uber" Microfiber Towels
Uber Drying Towels
Cam Spray 1500A with Cam Spray Foam Gun
Prep:
Swirls
Bug and tar
Wheels
Wheel well
Wash
Wheels/Tires/Wheel well
Pre soak
Dan foaming it up
Rinse
Claying
Polishing
Premier Performance
Compete
Performance
Lighter
Products Used:
Exterior:
Swissvax Finesse
Einszett Spray Wax
Wheels/Tires/Etc
Adam's VRT
Swissvax Autobahn
Tools:
Fenix TK11
Brinkmann MaxFire
Metabo PE12-175
Flex 3403
Uber Drying Towels
Prep:
Swirls
Bug and tar
Wheels
Wheel well
Wash
Pre soak
Dan foaming it up
Rinse
Claying
Polishing
Before shot of the top
Tape to test the area decided to go with Menzerna Super Intensive and the Uber Yellow pad
then finish it up with Menzerna PO85RD with the Uber Blue Pad
After SIP
After PO85RD
50/50
Me on the Flex 3403 is a blessing in disguise, its so light its enabling me to get back into the game
Dan polishing big assist as my hand is still out of wack
Various polishing shots
Rinse down due to dust
After SIP
After PO85RD
50/50
Asolutely gorgeous work and Pic set . Thank you for them.
I miss my s2000 deeply.
Where is your shop?
I would love to have my 911 detailed to this level.
I praise your attention to detail.
Where is your shop?
