drying your car
Old Sep 3, 2009 | 08:41 PM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
drying your car
is it ok to use the leaf garden blower for drying the car?
Old Sep 3, 2009 | 08:44 PM
MoeMistry's Avatar
Premium Sponsor
Not bad...just make sure there's some sort of filter on it. You don't want it picking up dirt, pollen, debris and blasting your car.
Old Sep 3, 2009 | 09:09 PM
solrac6262's Avatar
yeah you are right, maybe a rag as a filter jk
Old Sep 3, 2009 | 09:10 PM
MoeMistry's Avatar
Premium Sponsor
Burlap should do the trick....
Old Sep 3, 2009 | 09:24 PM
solrac6262's Avatar
that's a good idea...
Old Sep 6, 2009 | 06:40 PM
blitzo's Avatar
blitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to beholdblitzo is a splendid one to behold
if you dont have the leaf blower. i would consider the airmax that moe sells. it definitely helps get the majority of the water off the car especially the water in the cracks. love it. i still have to use a microdry towel to dry some stragglers but it minimizes the amount of drying by towel.
Old Sep 13, 2009 | 05:23 PM
cherzra's Avatar
cherzra is infamous around these partscherzra is infamous around these parts
I use a large microfiber towel. Before drying, try to "sheet" as much water as possible off of the car by layering water from a noseless nozzle. So you just remove the nozzle, then move it from left to right and let the water sheet down the car.
When drying, be sure to avoid motion as much as possible. Absorb the water and move to another spot, don't just drag the towel over the paint.
And yeah, you can use a leaf blower with no problem.
Old Sep 14, 2009 | 01:09 PM
SVTHorsnake's Avatar
SVTHorsnake is infamous around these partsSVTHorsnake is infamous around these parts
To add, if your car is well waxed, there's no better way to start drying than he described, just remember to have the spigot turned down very low to avoid splash. There shouldn't be too much moisture left if done right. I also ad a few distant, light sprays of quick wax on each panel before dragging the towel over it. Just helps to lubricate any remaining particles.
I'd generally avoid using landscaping equipment on cars. Not to be sarcastic, just doesn't seem go practice. If you're trying to get water out of crevices, run down to your local auto parts store and buy a cheap air compressor. It's less expensive and much more effective.
Old Sep 14, 2009 | 01:20 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
I use the jumbo fire hose nozzle for my final rinse. I sheets the water off the car instead of splashing. I then spray the car down with detail spray and use a jumbo waffle weave drying cloth to do the final drying. Works awesome and leaves no water spots. Just make sure you do the final drying in the shade or in a garage, so the water doesn't dry before you get to it.
I got both from Phil at Detailers Domain.
Old Sep 15, 2009 | 05:39 AM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
Let me know if you need any assistance we have all our items in stock.
thanks Tom for the suggestions.
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 09:56 AM
