Cleaning exhaust tips - what to use?
Old Oct 11, 2009 | 09:11 PM
factoryKITTED's Avatar
factoryKITTED is infamous around these parts
My side exhaust on my G55 is filthy - what do you guys recommend using? Tons of tar and the tips are black from the exhaust. I got the tar of with a paint thinner - worked really well. I want to make them look new again.
Thx.
Old Oct 11, 2009 | 09:19 PM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
the Zymol metal works really well for getting the tips really nice.
John
Old Oct 11, 2009 | 10:34 PM
MoeMistry's Avatar
Premium Sponsor
Check out this write up I did...it will lead you in the right direction
https://www.6speedonline.com/forums/...aust-tips.html
Old Oct 12, 2009 | 07:07 AM
Detailed Image's Avatar
Detailed Image is infamous around these partsDetailed Image is infamous around these parts
Good advice Moe. Here's another exhaust tip writeup that covers some regular wash maintenance techniques as well. Very similar restoration process using the 0000 grade steel wool.
Old Oct 12, 2009 | 07:37 PM
fantastic write up Moe - where can i buy the Zymol Metall towelettes?
Old Oct 12, 2009 | 09:11 PM
MoeMistry's Avatar
Premium Sponsor
Thanks...I should have noted...I no longer use the zymol Metall. We now use Menzerna Power Finish to polish the tail pipes. It gives the pipes a more polished and clean look.
http://www.glisteningperfectionstore...-Finish/Detail
Old Oct 13, 2009 | 09:46 AM
is there anything out there that i can pick up local that's worthy of buying?
Old Oct 13, 2009 | 10:48 AM
MoeMistry's Avatar
Premium Sponsor
There are stainless steel products out there at lowes or home depot. I would personally just get the intended products made for automotive use. We can get the products in your hands in a few days without breaking the bank...in the long run that's the best way to go.
Old Oct 13, 2009 | 11:06 AM
Whatcha got - the quad ought steel worked really well. They were beyond black!!!
Old Oct 13, 2009 | 11:37 AM
MoeMistry's Avatar
Premium Sponsor
Get the Total Auto wash. You can also use it to clean the engine, wheels, and door jams.
http://www.glisteningperfectionstore...to-wash/Detail
Then get the Menzerna Power Finish in the 16oz. This can be great also if you get little scuffs in the paint and you want to remove them by hand.
If you don't have any grunt towels, here are some good microfibers that are multi-purpose for such things as cleaning tailpipes:
http://www.glisteningperfectionstore...ICRO%2C/Detail
Old Oct 13, 2009 | 12:27 PM
The Menzeran Power finish seems a bit pricey for using it on the tips...is this what you are recommending?
Old Oct 13, 2009 | 12:30 PM
Scott997's Avatar
Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !
I recommend FLITZ works everytime, can get it at boating places or some hardware stores. It's a phenomenal metal polish.
Old Oct 13, 2009 | 12:31 PM
MoeMistry's Avatar
Premium Sponsor
The 16oz is not bad. I recommend it because of the results it get on the pipes. Also, it's going to be used elsewhere as well. You can polish the paint with it too. It's a product you'll wish you had when a shopping cart scuffs the bumpers or someone else backs into you and their paint is on your paint and you need something to safely remove the unsightly scuff.
If you're up to it, just add some wax to the order, and you'll be able to polish and wx the paint as well for a nice detail. Does that help?
Old Oct 14, 2009 | 07:54 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
+1 for Flitz. Great stuff and I use microfiber instead of steel wool to keep the chrome in shape. I've also found that P21S polishing soap is great to use after getting the real crud off the exhaust tips. It gets them cleaned up without having to use polish each time.
joseph_number1
Jul 19, 2018 05:45 PM
Apex Chase
Mar 28, 2016 02:00 PM
I'mAllIn
Sep 11, 2015 06:38 AM
ppwchiang
Aug 20, 2015 10:28 AM
